Need a complete surround sound system on a budget of $700. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 29 Old 11-12-2012, 03:06 PM - Thread Starter
HeadCrash20's Avatar
So my old Panasonic SA-HT05 finally gave up the ghost last night. The wife suggested getting a new system and wanted me to look into a Bose system. First thing I realized was that we couldn't even get there on our budget, but after reading many reviews and suggestions figured out that they seem to be way overpriced for what you get. So now I am looking at getting a system for around $700, might be able to stretch it to $800 with a little coaxing.
The problem with this is that unless it all comes in a box together, I have no idea what I should be getting and everything I have read says that you get your best bang for the buck by buying the pieces individually. So I am begging for the assistance off all you audiophiles here to help me get the best I can for my money. Thought this would be a good time to jump into this with Black Friday only being a little over a week away.
Thanks in advance for any suggestions you can provide,
~HeadCrash
HeadCrash20 is offline
post #2 of 29 Old 11-12-2012, 03:11 PM
smasher50's Avatar
Quoted: 354 Post(s)
Liked: 15603
what size room? and is this budget for speakers and a sub or just speakers and what will you be driving these speakers with
i'm so laid back,i'm laid out
smasher50 is offline
post #3 of 29 Old 11-12-2012, 04:27 PM - Thread Starter
The room is about 15'x15'. We will be moving in the next year, and the room in that house will end up being about 20-25'x12-15'. Also, I will need everything, speakers, sub, and a receiver to drive them all. I did find a Yamaha RX-V571BL on clearance at a BB about an hour away from me for $149, but I am not sure if that would be the best piece to start my system with or not.
post #4 of 29 Old 11-13-2012, 09:55 AM - Thread Starter
Since I am new to this forum, was this the correct place for me to put this request? Would I be more likely to get a response in another section?
post #5 of 29 Old 11-13-2012, 10:07 AM
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
in my opinion, you have the right idea by looking at best buy clearance and open box or display items. that is where i found some great deals too. look at best buy for the receiver and speakers, i would do an internet direct subwoofer though. here is my suggestion
Pioneer FS51 tower speakers - BB clearace for about $100 a pair
Pioneer C21 center speaker - BB clearance for about $50
Pioneer BS21 bookshelf speakers - BB clearance for $50 a pair if you want a 5.1 system, or two sets if you want a 7.1 system
Klipsch RW12D subwoofer - goes on sale on newegg.com regularly for $300
that leaves about $200 for the receiver of your choice.
mgrotel is offline
post #6 of 29 Old 11-13-2012, 04:46 PM - Thread Starter
Thanks for the suggestions mgrotel. I checked for BBs around me, but no luck. Could have found a couple of them, but they were in separate stores well away from each other.
post #7 of 29 Old 11-13-2012, 05:34 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
The Yamaha 571 is not a bad start for$150.
Add this system to it for $650 and you've got a nice little $800 5.1 package.
http://www.emptek.com/PreSeason.php
Djoel likes this.
Afro GT
afrogt is offline
post #8 of 29 Old 11-13-2012, 05:40 PM
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
i went to about 5-6 different stores to piece mine together. deals are out there, but you may have to sacrifice some of the convenience factor to get them. good luck
mgrotel is offline
post #9 of 29 Old 11-14-2012, 07:30 AM
[Irishman]'s Avatar
Quoted: 175 Post(s)
Liked: 121
He did say "complete". I would interpret that to mean an AVR, too.
COMING SOONFinding the Ark of the Covenant by Brian Roberts, in the iBook Store on iTunes, a new investigation into the Hebrew’s Most Sacred Relic!
[Irishman] is offline
post #10 of 29 Old 11-14-2012, 07:40 AM
Elihawk's Avatar
Quoted: 1014 Post(s)
Liked: 856
that EMP speaker set > way better that Pioneer Andrew jones > way better than Bose!
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is offline
post #11 of 29 Old 11-14-2012, 07:43 AM
Elihawk's Avatar
Liked: 856
You can get a set of NHT superzero 2.0 for 500 dollars- excellent 5.0, but then you would need a AVR and Subwoofer.
Elihawk is offline
post #12 of 29 Old 11-14-2012, 08:19 AM
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
what size are the woofers on the EMP 5.1? and i mean the woofers on the shelf speakers, not the sub.
mgrotel is offline
post #13 of 29 Old 11-14-2012, 08:22 AM
BrianArnold2's Avatar
i like my small paradigm cinema 90 setup i have in my living room right now.. doesnt compare to my bigger stuff in the theater room but is plenty lound and sounds great my living room is 13x24
BrianArnold2 is offline
post #14 of 29 Old 11-14-2012, 08:26 AM
afrogt's Avatar
Liked: 755
5.25"
The E5Bi Bookshelf speakers offers a great degree of flexibility and will add elegance into any home theater. The
5¼-inch aluminized poly-matrix woofer accompanied by a 1-inch fabric dome tweeter delivers effortless mid
and high frequencies. Available in high-gloss red burl or high-gloss black ash.
• 5-1/4" (133mm) Aluminized Poly-matrix Woofer
• 1" (25mm) Fabric Dome Tweeter
• Recommended Power: 50-100 Watts
• Impedance: 8 Ohms
• Frequency Response: 60Hz-20kHz ±3dB
• Crossover Frequency: 3,000 Hz
• Sensitivity: 85dB (2.83V@1m)
• Dimensions: 6-7/8" W x 12-3/4" H x 8" D
(175mm W x 324m H x 203mm D)
• Weight: 7.5 lbs. (3.40 kg.)
• Available in High-gloss Red Burl or High-gloss Black Ash
Afro GT
afrogt is offline
post #15 of 29 Old 11-14-2012, 08:47 AM
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
are those really going to be a better option than a full tower with 3 of the same size woofers like the pioneers?
mgrotel is offline
post #16 of 29 Old 11-14-2012, 09:31 AM
afrogt's Avatar
Liked: 755
You'd have to listen to both to see what you like better. Speaker preference is very subjective. If you've got room for towers then get the Pioneers. Plus you can purchase locally and return if it doesn't meet your expectations.
Afro GT
afrogt is offline
post #17 of 29 Old 11-14-2012, 09:56 AM
Elihawk's Avatar
Liked: 856
The Pioneers will hit lower, although I was not impressed with the quality of the low end- sounded muddled and not detailed (Pioneers spect suggest they can hit down to 47 hz, EMPs down to 60hz). wWth a sub, 60 hz is plenty low. I haven't heard the EMP bookshelves, but the the EMP-E5ti, with a similar EMP-made driver, is just really WAY better that the Pioneer tower speakers (more expensive, so not really a fair comparison). And the Pioneers are ugly...but all this is just my opinion!
Elihawk is offline
post #18 of 29 Old 11-14-2012, 10:38 AM
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
imo, it is silly to even compare any 5.25" driver with respect to frequencies below about 80hz because the speakers arenet designed for that, they are designed for midbass, imo. i would never ask any tower or shelf speaker with 5.25" drivers to play 40hz, let alone play it with good quality.
my pioneers sound awefully good crossed over at 80hz with a dual sub setup. but i tend to like their sound better than the harshness i hear from other speakers. its nice to be able to have it loud but not have it be hard on my ears. it is very easy to listen to them loud for an extended period of time. but like afro said, i guess at that point it is all very subjective.
mgrotel is offline
post #19 of 29 Old 11-14-2012, 11:14 AM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
I for one will not compare the Phase 1 Pioneer speakers, to certain brand speakers. > However for me
and a lot of other owners, we consider the Pioneer phase 2 speakers a step up. I will not/do not, put the
phase 1 on equal terms with the phase 2. > For me, the Phase 2 have opened up more, and with better
detail and a bigger soundstage. They still will not jump out at you, however the new line has opened up
the presentation. ALso for the speaker size, they have good bass, that is tight and articulate.
It all comes down to preference, choice and taste - however, for me they have raised the bar, and hold
up well against some more main-stream popular brands. I will continue to reccomend them as a option.
I have owned many speakers with a so-call small 5-1/4 inch woofer - that performed overall better, than
a lot of 6-1/2 inch woofers.
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #20 of 29 Old 11-14-2012, 11:25 AM
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
to each their own. i prefer the first pioneer series over the second series after seeing specs and listening to both personally. i suppose i am in the minority on this, but it is how i feel nonetheless.
mgrotel is offline
post #21 of 29 Old 11-14-2012, 11:29 AM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
It is all about, what brings you joy and pleasure.
Who AM I
zieglj01 is offline
post #22 of 29 Old 11-14-2012, 11:56 AM
Elihawk's Avatar
Liked: 856
yep. if those Pioneer speakers sound good to you, and the price is right...not much else matters!
Elihawk is offline
post #23 of 29 Old 11-15-2012, 07:23 AM
Gritter99's Avatar
interested to see what the top suggestion is!
Gritter99 is offline
post #24 of 29 Old 11-15-2012, 09:32 AM
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
another option:
jamo 5.0 - $200 - http://www.vanns.com/shop/servlet/item/features/544351896
klipsch rw12d sub - $300
yamaha receiver - $150
total - $650
mgrotel is offline
post #25 of 29 Old 11-15-2012, 02:32 PM
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
mgrotel is offline
post #26 of 29 Old 11-15-2012, 02:34 PM
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
mgrotel is offline
post #27 of 29 Old 11-16-2012, 08:53 AM - Thread Starter
Thanks for all the suggestions guys. Especially all the work done by Mgrotel. I would love to get that Klipsch RW12D sub, but it looks like it is priced $500 as of right now. I did just get an e-mail this morning that had a Polk CS2 Series 2 for $99, Polk Monitor 40 Series 2 for $110/Pair, and a Klipsch Synergy Sub-10 for $179. Was thinking about using those with the previously mentioned Yamaha receiver, but wasn't sure about it.
It would be
Polk CS2 - $100
Polk Monitor 40 (x4) - $220
Klipsch Sub - $180
Yamaha Receiver - $150
Total - $650
Another option that I have been leaning towards considering my total newbishness towards surround sound is the Onkyo HT-S9400THX for $730. More expensive, but it is 7.1. Also, I know it will all play nice together which I can't personally say about the other setup.
post #28 of 29 Old 11-19-2012, 07:56 PM - Thread Starter
Bumping this thread because my last post took 3 days to show up on here for some reason.
post #29 of 29 Old 11-19-2012, 09:40 PM
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
When I was first looking for my setup, I was really close to getting that 9400 HTIB. While my research showed that to be the best HTIB package, I read that the speaker quality is not great. I'm very glad I decided to assemble individual pieces. But I also prefer tower speakers.
mgrotel is offline
Reply Speakers
