5.1 setup help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 11-12-2012, 04:05 PM - Thread Starter
meltn02's Avatar
Hey guys, new poster to the forums, but have been reading posts on 5.1 advice and think I am finally ready to buy something and would greatly appreciate your input.
Here is what I have to work with:
Room - 20x14, cathedral ceiling, TV mounted above fireplace
Budget - ~$2000
The wife is really against a big bulky setup so anything like that is out of the question. After reading countless reviews I am leaning toward a KEF 305 setup due mainly to their good performance out of such a small footprint.
I would possibly consider a not-too-bulky floorstanding set if you guys don't think the KEF set will be able to fit my needs.
Also what receiver would you recommend (something that will be adequate but trying to keep cost low).
Lastly if I do get the KEF 305's would mounting them beside the TV cause any problems since it is just a little above head level while sitting?
Lots of questions but trying to be thorough with my info, also open to all suggestions....thanks in advance!
meltn02 is offline
post #2 of 8 Old 11-12-2012, 06:04 PM - Thread Starter
meltn02's Avatar
Forgot to mention this setup will be used 90% for Movies/TV very little music
meltn02 is offline
post #3 of 8 Old 11-12-2012, 07:13 PM - Thread Starter
meltn02's Avatar
No input at all? I am open to all suggestions on floorstanding speakers rather than the KEF 305's
meltn02 is offline
post #4 of 8 Old 11-12-2012, 10:27 PM
zieglj01's Avatar
Quoted: 1574 Post(s)
Liked: 1432
NHT will not be big and bulky
http://www.nhthifi.com/Home-Theater-Absolute-5-1T-System?sc=12&category=3830
__________________________________________
Who AM I
Speakers -- Snell K7 > Q Acoustics 3020 > Boston VS240
Receiver -- Integra 50.2
zieglj01 is offline
post #5 of 8 Old 11-12-2012, 10:41 PM
lespurgeon's Avatar
Quoted: 31 Post(s)
Liked: 52
KEF is a fine choice, but I would second the NHT.
Any way to mount that TV lower? My neck gets tired if I have to look up all the time when I watch videl.
lespurgeon is offline
post #6 of 8 Old 11-13-2012, 02:10 AM
GusGus748s's Avatar
Quoted: 423 Post(s)
Liked: 703
Yeah, NHT would be a good choice. Unless you go bookshelf all around, and a good sub. Look at HSU, or give a call to HTD. With HTD you can send them your blue prints and budget and they'll recommend you some speakers for your room.
GusGus748s is online now
post #7 of 8 Old 11-13-2012, 07:02 AM
zieglj01's Avatar
Liked: 1432
NHT, also does a good job with their bookshelf speakers.
Who AM I
zieglj01 is offline
post #8 of 8 Old 11-14-2012, 10:53 PM
Bytehoven's Avatar
Quoted: 55 Post(s)
Liked: 77
I just built a new 7.1 system for music/sound designing and mixing surround with (7) JBL Control 5 Monitors, a BIC PL-200 sub and Yamaha RX-A2020 receiver.
I needed a flat monitor design and I can confirm the JBL Control 5 monitors are very similar to the Yamaha NS10M monitors I use for mixing 2.0. The JBL monitors work very nicely with a 80hz sub cutoff. The Control 5 monitors are also front ported and are very barrier friendly. While I am installing significant bass trapping and early reflection acoustical treatments, I was surprised how well the raw setup performed in my 16x25 studio space.
The JBLs can be bought at $250-$350 a pair, which is not a bad price for a pro studio quality, passive, mid field design.
I adapted my old Paradigm MB-60 wall mount hardware for use with the JBLs which saved quite a bit of $$$.
Good luck with your new setup.
XBL GT: J05HB4G05H
PSN ID: Bytehoven
Battle Log: Bytehoven
Bytehoven is offline
Reply Speakers
