Cerwin Vega speaker replacement - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-15-2012, 09:53 PM - Thread Starter
mtmer's Avatar
I have a set of Cerwin Vega E-712 speakers. One of the mid range speakers is blown. I have looked for over a year trying to find a replacement but they don't make them anymore and no one has one. I was wondering if anyone could recommend another set of mid range speakers that I could replace both with. The numbers one the speaker are DM-13080 and LSCTJ2070. Thanks
mtmer is offline
post #2 of 5 Old 11-16-2012, 04:15 AM
wwinkler's Avatar
Quoted: 23 Post(s)
Liked: 31
You could contact Parts Express on whether they carry a drop-in replacement speaker for your Cerwin-Vega. If the issue with the mid-range is a repair, you could contact them
http://www.parts-express.com/speakerrepaircenter/index.cfm .
wwinkler is offline
post #3 of 5 Old 11-16-2012, 11:30 AM - Thread Starter
mtmer's Avatar
I tried that site and they do not have the E-712s listed for a speaker repair.
mtmer is offline
post #4 of 5 Old 11-17-2012, 07:13 AM
wwinkler's Avatar
Quoted: 23 Post(s)
Liked: 31
Try Google search on 'speaker repair cerwin vega'.
http://www.simplyspeakers.com/cerwin-vega-speaker-repair.html - for instance, you could try this place
wwinkler is offline
post #5 of 5 Old 05-02-2013, 08:46 PM
SoTweaked's Avatar
I'd check Ebay they have tons of cerwin vega stuff
SoTweaked is offline
Reply Speakers
