Can AVSForum help a newbie to build his first HT system?? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 39 Old 11-24-2012, 12:01 AM
GusGus748s's Avatar
Quoted: 428 Post(s)
Liked: 705
Amazon.com has speaker stands. That's where I bought mine.
GusGus748s is offline
post #32 of 39 Old 11-24-2012, 09:12 AM
skidog's Avatar
Liked: 27
I got a reciever from ac4l and had no issues and would not hesitate to buy from them again. I have a speaker package coming from Ascend so have not listened to them yet so I can't comment on sound but just thought i would tell you the CBM 170's are 50 dollars off at the moment for a pair which would put them just under 300, and the HTM 200SE center is 158.
Good luck I have had a htib for about 12 years but i just decided to finally step up and get something good and i can tell you I have gone well above where i wanted to go, with speakers, subs and reciever I'm sitting at about 2300 bucks about 1000 more than I originally wanted to spend!eek.gif
Hope I'm not dissapointed!
Panasonic TC-P65VT50
Denon 2113ci
Panasonic DMP-BDT220P
Ascend CMT-340SE L/R
Ascend CMT-340SE Center
Ascend CBM-170SE Surrounds
Klipsch RW12-D x 2
skidog is offline
post #33 of 39 Old 11-26-2012, 12:46 AM - Thread Starter
antoraj12's Avatar
Guys,
Any good SACD to test my new HT system?
antoraj12 is offline
post #34 of 39 Old 12-06-2012, 09:53 PM - Thread Starter
antoraj12's Avatar
Ok - I received my 3.1 system this week.
Denon 2113ci
HTD Level 3 bookshelf
HTD Level 3 cc
HSU STF-1 sub
Will be setting it up soon.
Will let you guys know how it works out!
post #35 of 39 Old 12-06-2012, 10:07 PM
NewHTbuyer's Avatar
Liked: 42
Originally Posted by antoraj12 View Post
Guys,
I asked this question myself and alot of people said that Pink Floyd, Dark Side of the Moon is a good test disc.
NewHTbuyer is offline
post #36 of 39 Old 12-07-2012, 12:17 AM
GusGus748s's Avatar
Quoted: 428 Post(s)
Liked: 705
Denon 2113ci
HTD Level 3 cc
HSU STF-1 sub
Let us know. I am thinking to do the same set up as you, but with the Denon 2313ci.
post #37 of 39 Old 12-08-2012, 09:12 AM
fsmithjack's Avatar
Great thread. I am thinking about going HTD's now. I have Martin Logan Motions 10 R&L - 6 Center - 2 Surrounds in my living room and want a system for my Living room. Do you guys think the HTD will sound better, crisper,fuller than the motions? Also, I am no expert and was wondering if the HTD Level 2 Towers would be better than the HTD 3 Bookshelves due to the HTD 3 Towers just being too much $$ and 2 towers and 3 book shelves being close enough $$/price wise to consider. My system will be 80% in HT and 20% music running through a 2112. I would love to hear more about how your system sounds when set up and feedback from those in the know about these HTD's possibility s. Thanks
fsmithjack is offline
post #38 of 39 Old 12-08-2012, 10:30 AM
GusGus748s's Avatar
Quoted: 428 Post(s)
Liked: 705
The only way to know if you are going to like the is if you audition them. What's sound good to me might sound bad to you. I've heard my friend's HTD Level 3 5.1, and it sound great for music and movies. HTD will let you try them for 30 days, if you don't like them they will pay for return shipping.
post #39 of 39 Old 12-08-2012, 01:00 PM
darkpoet25's Avatar
Liked: 40
Another one I would add would be the Dire Straits' Brothers In Arms SACD. You can get a copy on eBay or Amazon fairly cheap(less than $20 in most cases).
Cliff
darkpoet25 is offline
Reply Speakers
