Phase plugs... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 11-20-2012, 11:21 AM - Thread Starter
Elihawk's Avatar
Quoted: 1313 Post(s)
Liked: 1144
I am currently reading a speaker review over my work lunch hour and the reviewer keeps raving about a budget speaker with a true phase plug in its midrange driver. Can someone explain what a phase plug is and what it means, in terms of sound quality?
Set up #1: EMP e5Ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, SVS NSD SB12 sub, Marantz Slimeline 1504 AV receiver
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and EMPtek10i10i sub, Denon 1910 AV receiver
Set up #3: Philharmonics- BMR in a 2.0 system, music only, Yamaha RXV-363 AV receiver
Elihawk is offline
post #2 of 10 Old 11-20-2012, 11:31 AM
Bill Fitzmaurice's Avatar
Liked: 5627
Unless the driver is horn loaded it's pretty much eye candy, and probably not a phase plug at all, but rather a pole piece extension.
Bill Fitzmaurice is offline
post #3 of 10 Old 11-20-2012, 11:53 AM
Quoted: 992 Post(s)
Liked: 520
There's a lot of misinformation out there. Bill got it right.
In practical terms, what is falsely called a "phase plug" does nothing but lower the driver's efficiency a bit. And maybe arguably help it handle more heat/power.
It's a cosmetic, not a performance, choice for the most part.
A real phase plug has to cover substantially all of the driver's radiating surface to make a material impact. Funny thing is, actual phase plugs are often mis-named "waveguides" in "hi-fi" company propaganda.
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
post #4 of 10 Old 11-20-2012, 11:59 AM - Thread Starter
Elihawk's Avatar
Liked: 1144
Well, the guy who reviewed this speaker was pretty adamnant that it was rare FOR a speaker under 1000 dollars to have a true phase plugs. (BTW, this review was of the EMP E5ti). Exact quote from the article
"There are two 6.5″ poly-matrix woofers, a 5.25″ aluminized poly-matrix midrange (with a true phase plug), and a 1″ fabric dome tweeter under a dedicated screen. The driver compliment alone belies the price of these speakers. Usually, at sub-$1000, phase plugs are for show only and move in and out with the driver. This, however, was a real phase plug. "
http://www.reviewboard.com/05/183/e5ti-speaker-review
Okay, Bill knows his stuff, so lets rephrase the question- What is a pole piece extension and what it means in terms of sound quality?
Elihawk is offline
post #5 of 10 Old 11-20-2012, 12:05 PM - Thread Starter
Elihawk's Avatar
Liked: 1144
Thanks Bill and DS!
Elihawk is offline
post #6 of 10 Old 11-20-2012, 01:35 PM
Liked: 5627
The reviewer is mistaken. That's a direct radiating cone driver, and it does not have a phase plug. Phase plugs are used in the throat of a horn, to equalize pathway differences from the various points on the diaphragm to the throat:
http://www.centauriaudio.com.au/diy/plugs.html
Cone drivers typically have a dust cover (dome) over the pole piece. Some drivers omit the dust cover and rather than leave a gaping hole they use a pole piece extension, which visually resembles a phase plug. But it doesn't re-route the passage of sound waves coming from behind it, so it doesn't work like one.
post #7 of 10 Old 11-20-2012, 03:09 PM
Quoted: 992 Post(s)
Liked: 520
Oh, it's an audioholics "review." (I searched for the first sentence, and it came up as a reprint from AH.) Not surprising. They must have some undisclosed conflict of interest with that speaker company's parent, RDL or something like that, because any BS that company's propgandists feed AH instantly gets lapped up and regurgitated over and over again. (They have an article that's allegedly about "identifying high fidelity drivers" that has some good parts but also a fair bit of claptrap (including the stuff written about "phase plugs.")
AH does some good stuff. Hiring Josh Ricci to do sub testing was a stroke of inspiration. And they're right about wires (for the most part, except when someone gives Gene a badly-designed $60k speaker and he brags about the wires in it). But anything from this particular company is not going to be reviewed, but rather deified.
Serious Audio Blog
DS-21 is offline
post #8 of 10 Old 11-20-2012, 05:01 PM
JerryLove's Avatar
Liked: 82
Can the lack of a dust cover reduce compression under the cone?
Is there any wave-guide function at all of having a big piece of metal in the middle of your cone?
Won't that thing radiate heat and, in doing so, help cool the driver?
JerryLove is offline
post #9 of 10 Old 11-20-2012, 07:27 PM
Liked: 5627
Yes, but so will a porous dome or a vented pole piece.
None. And seldom are pole piece extensions more than an inch diameter anyway.
It can, but a vented pole piece works much better. With midranges and midbasses where you see them used there's usually not enough heat for it to be an issue to begin with.
post #10 of 10 Old 11-21-2012, 07:23 AM
Quoted: 992 Post(s)
Liked: 520
There is a good discussion of these polepiece extensions by serious home audio heavyweights (both "AndrewJ" and "speaker dave" have, I believe, designed loudspeakers rated "Class A" by Stereophile) starting here.
Serious Audio Blog
DS-21 is offline
Reply Speakers
