Klipsch RW-12D Owner's / settings Help!!! - Page 2 - AVS Forum | Home Theater Discussions And Reviews
Old 02-23-2013, 06:58 PM
sojodave's Avatar
Quoted: 16 Post(s)
Liked: 56
I got my Klipsch a few weeks ago and to get my sub -3db with Audyssey, I initially set my sub volume at -17. After a few weeks, I've had to reduce -23db. You should set your phase at 0 and and turn off your .lfe. Turn your lfe on your sub up to 120 and keep turning it and you will get lfe off. This will allow your AVR to control the lfe.
sojodave is offline
Old 02-25-2013, 10:41 AM
chintu30's Avatar
Hi All,
I just set up the following -
1. Energy 5.0 speakers
2. Denon 1913 AVR
3. Klipsch RW 12d
As others have stated on this thread, inititally I did get a small thump on the sub. But after I ran Audyssey again after fully setting things up quite a few times, it won't recognize the Sub at all! I have tried setting the volumes on the sub from -20 - 0db no luck! Here are my settings -
1. I set the Speakers to SMALL
2. Bass -
Subwoofer mode - LFE+Main
LPF - 120hz
3. Distances seemed fine on all the speakers, but it had 13ft on the Sub which was right next to the left speakers which were set to 8ft.
4. Test tone -
Front L - 0 db
Front R - +0.5 db
Center - -0.5 db
Surround R - +1.0 db
Surround L - 0.5 db
Sub Woofer - 6 db
5. Crossover
Front - 80 Hz
Center - 80 Hz
Surround - 80hz
On the Sub -
6. Volume - -23db
7. Phase 0
8. LFE off
I am concerned and I hope its not the sub itself...Because there was a point when I got the thumps! Any help would be greatly appreciated!
Regards
chintu30 is offline
Old 02-25-2013, 12:38 PM
sojodave's Avatar
Quoted: 16 Post(s)
Liked: 56
Unplug your sub and wait for 30 seconds and plug it back in and see if that resets it.
SanchoPanza likes this.
sojodave is offline
Old 07-24-2013, 09:35 PM
hank0's Avatar
I’ve had the Klipsch RW-12D for a week. I have a Yamaha RX-A820. To my understanding I need to find a volume on the sub that will allow Yamaha YPAO to set trim between -3 and +3. I read to start at 25% sub volume. After a few tries with YPAO, I got +2.5db on avr, with a sub volume of 60% (-10).
I have the sub itself set to Flat (not punch or depth). Phase is 0. Lowpass is 120hz. speakers are set to small(fluance XL series)
My question to owners of this sub, do my settings seem right? Because if the sub is set to 25% volume, YPAO sets the trim to +10db.
hank0 is offline
Old 07-24-2013, 11:31 PM
crn3371's Avatar
Quoted: 239 Post(s)
Liked: 192
With my A-720 a setting around -23db on the sub gives me around 0db when I run ypao. Your setting of -10 on the sub seems pretty high considering you're still getting a + reading on ypao. Perhaps it has to do with room acoustics or your placement.
hank0 likes this.
crn3371 is offline
Old 07-25-2013, 08:20 PM
hank0's Avatar
thanks for the reply crn3371. My placement is left Tower, then a foot of space, TV, SUB, right tower. Room is 13x16. After 2 weeks of playing around with the sub, I think it is defective. if I set my avr to 0db, the sub's bass only seems to start at -14 (50% volume). I've tried ypao many times and a few different placements.
a few ypao results are:
sub -17 avr +10
sub -15 avr +8
sub -13 avr +5
sub -10 avr +2
sub -7 avr 0
I think my sub is defective. I will return it.
hank0 is offline
Old 08-19-2013, 08:57 AM
shpitz's Avatar
Quoted: 66 Post(s)
Liked: 55
Hi everyone, I'm having a serious null at 50Hz in all sitting positions with two 12d's (each next to a front speaker).
This is roughly my setup:
Will changing phase do anything to help? any ideas? On the sides of the TV seems the most 'natual' placement. I read that it is recommended for a two-sub setup to put one in the front below the TV, and one across the room, behind the sofa, but that will look weird since I have the entertainment table the TV is currently sitting on (I plan on hanging it on the wall, but the table is likely to stay for now).
This is what Audyssey came up with: Onkyo TX-NR1010
Any ideas how to tackle this 50Hz null? If I stand up in the same spot, the bass is incredible!
shpitz is offline
Old 08-19-2013, 11:42 AM - Thread Starter
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
Speaker placement has a lot do with it. In my opinion your front set up is too close to each other. You might want to get rid of the towers and go with bookshelf speakers and mounting them on the wall.
GusGus748s is offline
Old 08-19-2013, 01:04 PM
shpitz's Avatar
Quoted: 66 Post(s)
Liked: 55
I actually replaced the fronts (pair of old bookshelves from an Onkyo HTIB) with these Infinity's, I really don't want to go back... frown.gif
I guess I'll keep playing around with placement.
shpitz is offline
Old 08-19-2013, 06:33 PM
LastButNotLeast's Avatar
Quoted: 1480 Post(s)
Liked: 1076
You know someone is going to recommend raising the couch, don't you? biggrin.gif
I presume you're measuring with REW or, at least, an SPL meter?
Changing the phase on one of the subs will probably help, but will take experimentation.
Good luck.
Michael
shpitz likes this.
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
LastButNotLeast is offline
Old 08-20-2013, 07:24 AM
shpitz's Avatar
Quoted: 66 Post(s)
Liked: 55
Haha, yeah, and actually, I would love to raise it, problem is the ceiling is not that high, not sure how that will work out...
I'm measuring with REW and a UMIK-1.
I'll play with the phase and see how that works... What ill affects does the phase have to the overall sound in the room? does the phase essentially 'delay' the signal a bit?
shpitz is offline
Old 08-20-2013, 11:34 AM
Liked: 1076
Apparently (and I'm NO expert in these matters), phase and distance are two different approaches to the same problem. If you have two speakers putting out the same signal, in some places the signal will be reinforced, in others it will be cancelled. What I did was change the phase on one sub and run an REW sweep. I think I did 30, 60, 90, etc. Pick the smoothest one and fine tune from there.
Might want to post your graphs here or on the REW thread.
http://www.avsforum.com/t/1449924/simplified-rew-setup-and-use-usb-mic-hdmi-connection-including-measurement-techniques-and-how-to-interpret-graphs
Old 08-20-2013, 12:00 PM
shpitz's Avatar
Quoted: 66 Post(s)
Liked: 55
Cool, I'll give that a shot...
Did you do all these adjustments on top of Audyssey?
What did you set the x-over to on the sub? 120? 80?
shpitz is offline
Old 08-20-2013, 12:08 PM
Liked: 1076
No, that was done with no eq (as should all speaker/listener/room adjustments; eq should be the LAST step).
XO on the sub is LFE mode (off); you want the AVR to handle xo.
shpitz likes this.
Old 08-20-2013, 12:15 PM
shpitz's Avatar
Quoted: 66 Post(s)
Liked: 55
Thanks for the info, i'll give it a shot.
shpitz is offline
Old 08-20-2013, 12:40 PM
Liked: 1076
Final phase sweeps (120, 140, 160, 180):
I picked the green one (which, of course, is purple below).
THEN add eq:
And enjoy!
Old 08-20-2013, 12:43 PM
shpitz's Avatar
Quoted: 66 Post(s)
Liked: 55
What do you mean by adding EQ? Apply Audyssey? use an Equalizer?
shpitz is offline
Old 08-20-2013, 12:47 PM
Liked: 1076
Yes. Either. Or, in my case, Equalizer APO, a fabulous software solution for HTPC.
http://sourceforge.net/projects/equalizerapo/
I use MCACC just to set the distances and delays.
Klipsch Rw 12d 12 Subwoofer Each , Subwoofers , Speaker Systems , Onkyo Ht S9100thx 7 1 Channel Receiver And Speaker Package
