If you had a $5k budget... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 11-21-2012, 08:01 AM - Thread Starter
purbeast's Avatar
Quoted: 14 Post(s)
Liked: 27
... and you had to purchase 5 speakers (going to be a 5.1 setup, but the sub isn't in the $5k budget), and your primary usage was for movies/games, with some sports/tv as well and then music as the last priority, what would you purchase?
Right now I am leaning towards purchasing a B&W setup - CM9's for front, CMC2 for center, and CM5 for surrounds.
I initially wanted to purchase the Klipsch RF7 II's, RC64 II, and RS62 II and went and demo'd it at someone's personal HT, and did enjoy it a lot although noticing the horn.
I then went and demo'd some more speakers at a store before I was to make my decision - B&W, Monitor, and Golden Ear (and the RF7's again at this store for comparison purposes).
After hearing those, I started to lean towards the B&W setup. While I wasn't too impressed with the Golden Ear or Monitor speakers (compared to the other 2), I overall liked the sound of the B&W better, and after listening to the RF7's for a while I was wondering if that horn would bother me after a 2 hour movie. I was starting to get that minor piercing feeling in my temple from the high-pitch horn in the Klipsch. In general I'm very sensitive to high pitched things. So putting all of that together, my current front runner is that B&W setup.
I am planning on possibly making the purchase this weekend since I have some time off of work and it is a long weekend. However before I make the plunge on a $5k purchase, I did want to hear some other opinions on speakers that others think could out-do my current front runner in the movie/gaming department. This does have to be something I can demo locally (I'm in the DMV area) since I'm not going to spend $5k without hearing them beforehand (duh!).
So does anyone else have any other suggestions that I should try to find and demo?
I also feel that I'm at the point that no matter what I do purchase, I'm going to be extremely happy with it. It's like trying to pick between 3-4 different hot chicks - either way you come out a winner!
I just hope I'm not overthinking my decision with all of this questioning!
purbeast is offline
post #2 of 10 Old 11-21-2012, 08:08 AM
Lepus's Avatar
Don't know if Paradigm were on your list, but you might be able to pick up some Monitor 9s, Center 3, Surround 3s and a nice sub for under 5k. Maybe even get some Surround 1s. What receiver are you using?
Lepus is offline
post #3 of 10 Old 11-21-2012, 08:10 AM
AcuDefTechGuy's Avatar
Quoted: 175 Post(s)
Liked: 262
I would say B&W, Revel, KEF.
I would aim for 10-20% discount from MSRP.
For example, going with my 20% off, the KEF R700 x 2 = $2900; KEF R300 x 3 = $1900; total $4800.
But if you like B&W the best after you listened to Revel, KEF, Focal, Dynaudio, and everything else, then buy the B&W.
AcuDefTechGuy is offline
post #4 of 10 Old 11-21-2012, 08:23 AM
Hookedonc4's Avatar
Quoted: 26 Post(s)
We currently use James Loudspeakers and love them. Really like the look of the new QX series. Let your ears make the decission. Have fun...
http://www.jamesloudspeaker.com/index.cfm?page=by_series&id=32
Denon X4000, SC-91, VSX-51,VSX-81 Pioneer Elites and Denon 1611
James loudspeaker inwalls main and future theater
Control4
Other speaker zones DefTech, Polk, Russound, Boston Acoustics
Hookedonc4 is offline
post #5 of 10 Old 11-21-2012, 08:24 AM - Thread Starter
purbeast's Avatar
Quoted: 14 Post(s)
Liked: 27
Well I'm not looking to put the sub in the $5k budget. I'm probably going to be spending an additional $2k - $3k on a good sub setup after I get these.
I'm going to be powering these with a Denon 4311ci.
I just found a place that is fairly local that has Revel and Paradigm:
http://evolutionav.com/evoupgrade/new/
I am going to check them out on Friday most likely and will see how those compare to the B&W. I found a place locally that is listed from the Kef website and just gave them a call to see if they have a showroom, however they did not pick up so I left them a message.
purbeast is offline
post #6 of 10 Old 11-21-2012, 08:27 AM
Quoted: 175 Post(s)
Liked: 262
Yes, compare Revel and KEF to the B&W.
And I think the Denon 4311 will have no issues powering these speakers. No problems at all.
post #7 of 10 Old 11-21-2012, 12:12 PM
callas01's Avatar
Quoted: 829 Post(s)
Liked: 463
http://www.jsaudio.com/
they have dynaudio that AcuDefTechGuy mentioned above and should be pretty close to you too.
Dynaudio Focus 260s, Focus 210C, DM 2/6, Hsu VTF3 MK5 HP, Oppo BDP-103, NaimUniti 2, Naim Stageline N, Pro-ject 2xperience Classic, Marantz SR7007, 60" 4K Samsung LED LCD
callas01 is online now
post #8 of 10 Old 11-21-2012, 12:16 PM - Thread Starter
purbeast's Avatar
Quoted: 14 Post(s)
Liked: 27
Ah cool thanks for that. They are about 15 minutes from me. I'll definitely check them out as well thanks!
purbeast is offline
post #9 of 10 Old 11-22-2012, 04:01 PM
6SpeedTA95's Avatar
Quoted: 145 Post(s)
Liked: 45
PSB Imagines should be on your list to audition. You should also checkout the Salk HT2-TL and the Salk Supercharged Song tower and center. I would also try to audition Ascend Acoustics Sierra Tower.
6SpeedTA95 is offline
post #10 of 10 Old 11-22-2012, 04:33 PM
jima4a's Avatar
Quoted: 275 Post(s)
Liked: 146
Kef R700s w/R600 center and R300 surrounds would be incredible.
Main Kef: Reference 205/2 & 202/2c, Surrounds: Kef XQ40, Velodyne Optimum 12, Integra DHC 80.3, Ayre K-5xeMP, Oppo BDP-103, Bryston 4Bsst2, Parasound Halo A31. Second B&W: 685 (3), CCM618, Def Tech Powerfield 1500, Onkyo TX-NR1008, Zone 2 Klipsch AW650.
jima4a is offline
Reply Speakers
