AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   Speakers (http://www.avsforum.com/forum/89-speakers/)
-   -   Buying my first HT 5.1 system, need your help !! (http://www.avsforum.com/forum/89-speakers/1440504-buying-my-first-ht-5-1-system-need-your-help.html)
Ivargat 11-21-2012 03:55 PM
Hello,
I am planning to buy my first 5.1 HT system this coming week so I would like to seek advice from you guys before ordering. The HT will be setup in my apartment hall (size 25 x 15 feet) and will be mostly used for TV, audio CDs and FM radio. I would also like to keep the budget below $1000.
I have zeroed in on below configuration -
Speakers -
L/R : Polk Monitor 40 for $109 (20-125w / 47Hz-25kHz / 8ohm / 89db) http://www.newegg.com/Product/Product.aspx?Item=N82E16882290202
Center: Polk Monitor CS2 for $149 (20-175w / 50Hz-25kHz / 8ohm / 90db) http://www.newegg.com/Product/Product.aspx?Item=N82E16882290212
Sub: Polk Audio PSW505 12-Inch Powered Subwoofer for $250 (23Hz - 160Hz ) or BIC America F12 12-Inch for $ 200 (25Hz - 200Hz)
Surround: TBD
Receiver -
Denon - 600W 5.1-Ch. Model: AVR1613 for $300
I am proceeding in the correct path ? Should I change any of my above configuration? I also need your advice on finalizing the sub and selecting the surrounds.
Thanks for your help !!!
bradymartin 11-21-2012 04:31 PM
im pretty much still novice here but i will add the Polk PSW505 is $229 shipped on amazon. i have the bic f12. it is boomy with music, people will say the polk is better with music.
afrogt 11-21-2012 08:12 PM
Where are you located Ivargat?
Ivargat 11-21-2012 08:56 PM
Ivargat 11-22-2012 09:41 AM
I was checking the forum... I see good reviews on HTD systems, how will below configuration stack up against Polk setup?
Speakers-
L/R : HTD level TWO bookshelf for $199 (Frequency Response: 60 Hz - 20 kHz, Impedance: 8 ohms,,Sensitivity: 87dB)
Center: HTD Level TWO Center Channel Speaker for $129 (Frequency Response: 52 Hz - 20 kHz,Impedance: 8 ohms,Sensitivity: 89dB)
Sub: BIC America F12 12-Inch for $ 200 (25Hz - 200Hz)
Surround: TBD ( $150 budget)
Receiver -
HTD setup will cost me about $200 more than Polk, is the difference in quality worth the money? What do you guys think ? I am relying on this forum to finalize.
Thanks !!
zieglj01 11-22-2012 09:55 AM
Speakers-
I will hands down take the HTD over the Polk Monitors, I consider HTD in a higher league and
they are built better.
As for surrounds, AC4L has Acoustic Energy speakers new in the box, and the Black Friday
price is 30% off - this will keep them in your surround budget. They use to list for $250 ea.
The price will change in the cart.
http://www.accessories4less.com/make-a-store/item/ACENAEGOTSAT/ACOUSTIC-ENERGY-AEGO-AE12-10-T-Series-4in-Satellite-Speaker-Black-Each/1.html
Ivargat 11-22-2012 11:14 AM
ok, looks like its HTD !!!
Few more questions ..
Should I pick up a refurb DENON AVR-1712 for $ 270 instead of new Denon AVR- 1613? Which one is better for the HTD setup?
Also,is the Polk Audio PSW505 12-Inch sub better than BIC America F12 12-Inch ? they only cost $50 more.
Thanks!!
zieglj01 11-22-2012 11:23 AM
Thanks!!
I prefer the 1712 at 90 watts
As far as a sub, I am not big on either one - however, if also going to listen to music,
then I would lean towards the Polk.
afrogt 11-22-2012 11:47 AM
Was going to recommend you check out Fry's for the Denon 1913 which will be $288 on Friday but you don't have one close by. Its an in-store only deal.
that Polk CS2 center is on sale for $99 today only with promo code EMCJJJD23 but if you're going with the HTD then never mind.
I'd get the Denon 1712 over the 1613 also.
Ivargat 11-22-2012 11:03 PM
Is there a better sub that will go with HTD around the $250 price point?
zieglj01 11-23-2012 06:33 AM
A better sub will cost more, how much overall bass are you looking for.
Ivargat 11-24-2012 01:02 AM
Honestly, I have no idea. I am relying on this forum.
GusGus748s 11-24-2012 02:56 AM
I would to all around HTD.
zieglj01 11-24-2012 08:32 AM
My recommendation is HSU
http://www.hsuresearch.com/products/vtf-2mk4.html
However, I do understand if one has a budget
If you can swing/stretch above the budget some - then I would go for the
HTD Level Three sub - and ask them about a speaker package >> They
have done package deals before.
http://www.htd.com/Products/level-three-speakers/Level-THREE-Powered-Subwoofer
If budget is strict and tight - then the EMP sub, to begin the journey
http://www.emptek.com/es1010i_bf12.php
HDTBill 11-24-2012 09:29 AM
... I was going to say Hsu also for that bottom sub. Glad the other poster agrees as I am out-of-date.
I have the older model classic Hsu for $500 but perhaps I wished I had got the little smaller Hsu.
I don't know product line-up today but the Hsu jr. was a good little sub in the affordable range.
But the clear base sounds real good, and can be tuned to come in when you need it as far as frequency.
Ivargat 11-27-2012 10:23 PM
I ended up ordering PSW505 sub, HTD speakers and Denon 1712 !!
Waiting for arrival now. ...
Thanks to everyone for help.
zieglj01 11-27-2012 10:27 PM
Good Luck and Enjoy!
GusGus748s 11-28-2012 12:37 AM
HTD speakers and Denon 1712 is a good buy. I would of gone with BIC F12 sub rather than PSW505.
Ivargat 11-28-2012 07:21 AM
I see lot of folk's in this forum recommend the polk sub for music so I based my decision on that. I will be doing 80 % music, 15 % TV and 5 % movies in this setup.
If I bump my sub budget to 300, are there any better options?
XStanleyX 11-28-2012 07:39 AM
Yes, when the Klipsch is back in stock and is back on sale for $300.
http://www.newegg.com/Product/Product.aspx?Item=N82E16882780078
Ivargat 11-28-2012 07:42 AM
It says out of stock now...price is also 499 now frown.gif.
XStanleyX 11-28-2012 07:45 AM
ETA for being back in stock is tomorrow. You'll have to wait til they are on sale. That "usually" happens on the weekend. If not this weekend maybe the next.
Your patience will be rewarded.
GusGus748s 11-28-2012 08:41 AM
BIC F12 is on sale for $198.00. You will have to go into the $500 to get a better sub unless you get a level 2 sub from HTD for $329.00. If the Polk sub will do good for music just use it. Remember is what you like not what other people recommend. A lot of people recommended the new Phase 2 Pioneers and I ended up with the Polk Audio Monitor 70's with Klipsch RW-12D sub.
zieglj01 11-28-2012 08:58 AM
I am not a Polk or Bic fan - however, I would buy the Polk for the more music side. When you
are able to upgrade, I would also skip the Klipsch for mainly music listening.
Good Luck with your journey.
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
