Building my first set up on Black Friday HELP!!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-23-2012, 09:49 AM - Thread Starter
BigZeus's Avatar
So far I have purchased a Sharp 70le640u and a Yamaha R-XV671. I cant decide between the Andrew Jones Pioneer SP-FS52 set up or going with the Polk Monitor 60 series II that is on sale on Newegg.com today. Also is the Yamaha a better receiver than Pioneer 1022? I bought it for $299 as Amazon DOD. But the 1022 is $249 on newegg today as well. Any suggestions would be greatly appreciated.
BigZeus is offline
post #2 of 5 Old 11-23-2012, 10:50 AM
afrogt's Avatar
Quoted: 1064 Post(s)
Liked: 769
unless you need Airplay I'd rather have the Yamaha.
As far as the Andrew Jones Pioneers vs Polk Monitor 60, go to your local Best Buy and listen to both. The Monitor 60 equivalent is the Tsi400. Usually BB has the Polks and Pioneers right next to each other.
The Polks will be louder due to higher sensitivity but they don't necessarily sound better.
BigZeus likes this.
Afro GT
afrogt is offline
post #3 of 5 Old 11-23-2012, 01:25 PM - Thread Starter
BigZeus's Avatar
Im thinking about going with the Pioneer pk52 fronts and c22 center. Then a Polk PSW10 sub and Im not sure about the rears. Thats good to know about the airplay. I have an apple tv and I beleive I will stick with the Yamaha I have read some positive things about it.
BigZeus is offline
post #4 of 5 Old 11-23-2012, 04:04 PM
afrogt's Avatar
Liked: 769
If you already have Apple TV then you don't need Airplay.
Polk PSW-10 sucks. No guts.
Either one of these would be better than the Polk PSW-10 for about the same price.
http://www.parts-express.com/pe/showdetl.cfm?partnumber=300-629
http://www.parts-express.com/pe/showdetl.cfm?partnumber=300-628
Now if you're ready to spend $200 for a sub then get the Bic F12 or Polk PSW-505.
http://www.amazon.com/BIC-America-F12-475-Watt-Subwoofer/dp/B0015A8Y5M/ref=sr_1_1?ie=UTF8&qid=1353711823&sr=8-1&keywords=Bic+F12
http://www.amazon.com/Polk-Audio-12-Inch-Powered-Subwoofer/dp/B000092TT0/ref=pd_cp_e_0
Afro GT
afrogt is offline
post #5 of 5 Old 11-25-2012, 08:46 AM - Thread Starter
BigZeus's Avatar
I think I will swap for the Polk 505. I ended up going with Pioneer SP-FS52 speakers. I was wondering seeing my receiver is 7.1 what would you suggest for the two mid speakers? Thanks again for all the info!
BigZeus is offline
Reply Speakers
