Can polk monitor 40's handle the wattage please help! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-23-2012, 09:14 AM - Thread Starter
Jjay92597's Avatar
This maybe a newbie question but I found a receiver I like but I fear it may overpower my polk audio monitor 40's. The receiver is Sony STR-DN1030 it claims to put out 145 watts per channel while the polk audio monitor 40's say they handle 20-125 watts. If I use this receiver will it damage my speakers? Or are the numbers just inflated? Or can I turn down the volume on the receiver to not damage speakers? Any help appreciated!
Jjay92597 is offline
post #2 of 5 Old 11-23-2012, 09:26 AM
XStanleyX's Avatar
Liked: 1270
This is the actual wattage I came up with when googled.
•100 watts per channel into 8 ohms (20-20,000 Hz) at 0.09% THD, with 2 channels driven.
You control the volume. If it starts clipping just back off.
XStanleyX is offline
post #3 of 5 Old 11-23-2012, 09:33 AM - Thread Starter
Jjay92597's Avatar
Thanks for such a fast reply! So basically the receiver is 100 watts? Second even if it is to powerful I can turn down the volume on the receiver an I will be fine?
post #4 of 5 Old 11-23-2012, 09:34 AM
XStanleyX's Avatar
Liked: 1270
post #5 of 5 Old 11-23-2012, 09:38 AM
zieglj01's Avatar
Quoted: 1678 Post(s)
Liked: 1577
There seems to be too much fear concerning receivers. Most of
the time people do not drive the sound, to max volume.
__________________________________________
Who AM I
Speakers -- Snell K7 > Canton GLS 2 > Boston VS240
Receiver -- Integra 50.2
zieglj01 is offline
Reply Speakers
