will klipsch RF 82ii setup work with yamaha v673..please help. - AVS Forum | Home Theater Discussions And Reviews
Old 11-23-2012, 10:58 AM - Thread Starter
audiobuff's Avatar
Hi all,
this forum is great in teaching me new stuff about the audio world.
Can anyone tell me if this combination of receiver and speakers would work. Does my receiver has enough power. do I need am amp as well.
My receiver is Yamaha rx 673
7-channel
90W per channel (8 ohms, 20 Hz-20 kHz, 0.09% THD, 2ch driven)
105W per channel (8 ohms, 1 kHz, 0.9% THD, 2ch driven)
and the setup I am trying to get for around $2100..i am almost about to pull the trigger on this one.
klipsch 5.1 with
2 RF-82II Towers
Power Range 50-150
Frequency Response 33-24k Hz
Sensitivity 98 dB
Impedance (Ohms) 8
1 RC-62 II Center Power Range 50-150
Sensitivity 98 dB
Impedance (Ohms) 8
Frequency Response 57-24k Hz
2 RS-52II Surrounds
Power Range 25-100
Sensitivity 95 dB
Impedance (Ohms) 8
Frequency Response 58-24k Hz
SW-310 Subwoofer.
Low-Pass Crossover Freq 40-150
High-Pass Crossover Freq N/A
Phase Switch Yes
Amplifier Output (watts) 400
Frequency Response 24-120 Hz
audiobuff is offline
Old 12-04-2012, 01:16 AM
John Ro's Avatar
i have the yamaha 673 and just purchased RF-82
John Ro is offline
Old 12-04-2012, 09:23 AM - Thread Starter
audiobuff's Avatar
Nice to learn that u got your a klipsch and a Yamaha. When I contacted Klipsch the tech told me to upgrade my receiver so that I don't blow off Klipsch's tweeters, i went with Yamaha aventage A2020 in the end. Although other ppl told me 673 would work just fine. I didn't want to risk my first system. Just my 2 cents .
Old 12-05-2012, 02:17 AM
John Ro's Avatar
ahh man imma listen to you and return my yamaha 673
John Ro is offline
Yamaha Rx V673 Receiver , Klipsch Reference Series Rf 82
