Budget system with satellites/bookshelves - AVS Forum | Home Theater Discussions And Reviews
post #1 of 22 Old 11-23-2012, 05:53 PM - Thread Starter
djtoodles's Avatar
What do you guys recommend on a budget system with satellites/bookshelves? I was going to originally buy the polk monitor 40's but they are too big. The monitor 30's will just fit in the area so I am wondering what you guys recommend for about $300-400 for a full setup of speakers, center and sub. My problem is space so I will need something smaller than the monitor 40 bookshelves and a center that is smaller than the polk Polk Audio CS2 Series II Center Channel Speaker.
djtoodles is offline
post #2 of 22 Old 11-23-2012, 06:19 PM
Kini62's Avatar
Quoted: 1743 Post(s)
Liked: 1557
You're not going to get much if you want a sub and 5 speakers for $400.
You'd be better off with a 2.1. Like a pair of NHT SuperZero 2s (or similar) and a $200 Bic or Polk sub.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #3 of 22 Old 11-23-2012, 06:31 PM
Hookedonc4's Avatar
Quoted: 26 Post(s)
These are agreat little speaker setup...
http://www.newegg.com/Product/Product.aspx?Item=N82E16882325104
Denon X4000, SC-91, VSX-51,VSX-81 Pioneer Elites and Denon 1611
James loudspeaker inwalls main and future theater
Control4
Other speaker zones DefTech, Polk, Russound, Boston Acoustics
Hookedonc4 is offline
post #4 of 22 Old 11-23-2012, 10:15 PM
afrogt's Avatar
Quoted: 1435 Post(s)
Liked: 982
So get two pair of Monitor 30's and a CS1 center.
Monitor 30 $79/pr
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290200
CS1 center, $59
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290210
That's $220 for 5 speakers shipped. Then add a subwoofer for $180 or so and you're set!
Dayton 12" sub, $100
http://www.parts-express.com/pe/showdetl.cfm?partnumber=300-629
Bic V1220, $180
http://www.amazon.com/BIC-V-1220-430-Watt-Down-Firing-Subwoofer/dp/B0000Y2WYS/ref=sr_1_1?ie=UTF8&qid=1353737645&sr=8-1&keywords=bic+v1220
Bic F12, $200 (slightly over budget)
http://www.amazon.com/BIC-America-F12-475-Watt-Subwoofer/dp/B0015A8Y5M/ref=sr_1_2?ie=UTF8&qid=1353737645&sr=8-2&keywords=bic+v1220
Afro GT
afrogt is offline
post #5 of 22 Old 11-23-2012, 11:45 PM
zieglj01's Avatar
Quoted: 1713 Post(s)
Liked: 1627
This is the main challenge for the OP - it is speaker placement. Not much area to
properly place the speakers. Also, will be a challange for rear ported speakers >
plus, larger type speakers.
http://www.avsforum.com/t/1434512/help-with-speaker-purchase#post_22514260
__________________________________________
Who AM I
Speakers -- Canton GLS 2 > Boston VS240
Receiver -- Integra 50.2
zieglj01 is offline
post #6 of 22 Old 11-23-2012, 11:46 PM - Thread Starter
djtoodles's Avatar
I can't seem to find dimensions on the cs1. Is it smaller than the cs2? The cs2 was too big for the area.
post #7 of 22 Old 11-23-2012, 11:50 PM
zieglj01's Avatar
Liked: 1627
These are the measurements
Height
7" (17.78cm)
Width
18" (45.72cm)
Depth
9 5/8" (24.45cm)
Who AM I
zieglj01 is offline
post #8 of 22 Old 11-24-2012, 09:11 AM - Thread Starter
djtoodles's Avatar
Height
7" (17.78cm)
Width
18" (45.72cm)
Depth
9 5/8" (24.45cm)
Thanks for that. Yeah I am
Starting to wonder if I should mount the tv which will give me whatever height I need below it for fronts and a center. The cs1 may work I will re-measure.
Is this setup any good or is the monitor 30 with cs1 center better?
http://amzn.com/B000WGJX5A
post #9 of 22 Old 11-24-2012, 09:39 AM
zieglj01's Avatar
Liked: 1627
I would mount the TV over stuffing rear ported speakers, in a cubby hole.
Bigger speakers can give you bigger sound - you have a tough set-up.
If you can not raise the TV - then this Definitive package, can work for you.
And will be better than TV speakers.
Polk or not, is up to you.
Who AM I
zieglj01 is offline
post #10 of 22 Old 11-24-2012, 11:20 AM - Thread Starter
djtoodles's Avatar
The brand is not really that important to me. I have just heard great things about Polk. The room is only 12x12 so I assume I would get big sound from almost anything.
post #11 of 22 Old 11-24-2012, 11:26 AM
afrogt's Avatar
Liked: 982
I would take the Monitor 30's and CS1 over either one of those satellite speaker packages.
Afro GT
afrogt is offline
post #12 of 22 Old 11-24-2012, 12:00 PM - Thread Starter
djtoodles's Avatar
should the sub be next/behind you or in front of you? if it needs to be in front the only way i can get everything to fit doing the CS1 sub and either monitor 30 or monitor 40's is to put 1 of the speakers behind the tv. otherwise I will need a smaller sub. The sub height or width can be as much as 17" but either height or width cannot exceed 11.5"
So in short I either need a speaker behind the tv and any sub listed above will work, OR a smaller sub.
post #13 of 22 Old 11-24-2012, 12:09 PM
zieglj01's Avatar
Liked: 1627
The sub can be used as an end table if needed, you do not need a giant sub
for your listening area.
Again, I would not put speakers behind your TV - it hinders your sound. If you
are going to do that, then get some cheap Dayton speakers.
Who AM I
zieglj01 is offline
post #14 of 22 Old 11-24-2012, 12:21 PM - Thread Starter
djtoodles's Avatar
post #15 of 22 Old 11-24-2012, 12:26 PM
zieglj01's Avatar
Liked: 1627
Pioneer for sure, if you set them up properly.
Polk is sub-standard for me, and I have owned both Polk and Pioneer speakers.
Who AM I
zieglj01 is offline
post #16 of 22 Old 11-24-2012, 12:34 PM - Thread Starter
djtoodles's Avatar
WHy do you say that? The pioneer is a cheaper setup as well. I have only ever heard great things about polk.
post #17 of 22 Old 11-24-2012, 12:41 PM
zieglj01's Avatar
Liked: 1627
You can buy what you want - it is your call.
It is not all about price - that is close-out pricing on the Pioneer.
It is not all about pricing - it is about overall performace. Good
speaker reviews are easy to find for most products.
You may like Polk, they are not my preference.
Just about anything, will sound better than TV speakers.
Who AM I
zieglj01 is offline
post #18 of 22 Old 11-24-2012, 12:43 PM - Thread Starter
djtoodles's Avatar
I am all about options:)
how is this for a sub?
http://www.amazon.com/BIC-AMERICA-V-80-Powered-Subwoofer/dp/B00009WBYK/ref=sr_1_1?s=electronics&ie=UTF8&qid=1353789751&sr=1-1&keywords=bic+v80
post #19 of 22 Old 11-24-2012, 12:55 PM
zieglj01's Avatar
Liked: 1627
Not for me, > The Outlaw M8, or this Acoustic Energy subwoofer, are just
about the only 8 inch subs - that I would seriously consider.
http://www.accessories4less.com/make-a-store/item/ACENAEGOSUB/ACOUSTIC-ENERGY-AEGO-AE12-08-T-Series-200-Watt-Dual-8in-Subwoofer-Black/1.html#!specifications
The Acoustic Energy Black Friday special, is $192.00
Who AM I
zieglj01 is offline
post #20 of 22 Old 11-24-2012, 01:08 PM - Thread Starter
djtoodles's Avatar
I think i am going to order the receiver and speakers today then get it setup how i like and decide where to put sub after.
post #21 of 22 Old 11-24-2012, 02:49 PM - Thread Starter
djtoodles's Avatar
Last question hopefully smile.gif... what gauge speaker wire should I buy?
post #22 of 22 Old 11-24-2012, 03:26 PM
zieglj01's Avatar
Liked: 1627
Since wire is cheap - I use 14awg
Who AM I
zieglj01 is offline
Reply Speakers
