Speaker wire question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-23-2012, 07:43 PM - Thread Starter
dude101's Avatar
Hello,
I moved into a new house with build in JBL speakers and banana plugs to connect them to. I recent bought a Yamaha V671 receiver but I also bought this cheap wire: http://www.amazon.com/gp/product/B0029HO66G/ref=oh_details_o00_s00_i00
I figured since the wire length between the receiver and will be around a foot it was no big deal to get cheap wire. Did I make a mistake? I don't know what the wiring is inside the wall for the built in speakers.
dude101 is offline
post #2 of 4 Old 11-23-2012, 09:12 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4776
lovinthehd is offline
post #3 of 4 Old 11-24-2012, 06:17 AM
drunkpenguin's Avatar
Quoted: 1276 Post(s)
Liked: 1263
Take one of your speakers apart and even on expensive speakers you're probably not gonna find monster cable. I took a physics class in college and she covered speaker wire. It was a very interesting section of the class. Turns out gold plated speaker wire benefits your dog more than it does you! Of course she was hot and I would have beleived anything she taught me. She had the power to turn me over to the Bose side if she had wanted to. Her boyfriend drove a Ferrari, I just couldn't compete with that.
Just 'cause you're right doesn't mean I'm wrong
drunkpenguin is online now
post #4 of 4 Old 11-24-2012, 10:31 AM
JerryLove's Avatar
Liked: 81
Plating (such as gold) on the contact points (where one wire meets another, or where it meets a post) can help to prevent oxidation from interfering with conductivity.
I'm not sure if it kicks in at the levels of a speaker wire: but I used to have the issue with tin leads on IC chips (you could also solve the problem when it occurred with a pencil eraser).
OTOH: I've seen gold plated optical cables. Really.
JerryLove is offline
Reply Speakers
