In Wall Speaker Recomendation - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: which in wall speakers to pick?
Klipsh R-55-2 0 0%
Klipsh KL-6502 0 0%
Yamaha NS-IW660 0 0%
Yamaha NS-IW960 0 0%
Definitive Technologies DI 6.5 LCR 0 0%
Definitive Technologies DI 5.5 LCR 0 0%
Get a divorce 0 0%
None of the above 3 100.00%
Multiple Choice Poll. Voters: 3. You may not vote on this poll
post #1 of 1 Old 11-24-2012, 02:02 PM - Thread Starter
FidelityIsKing's Avatar
Installing a finished basement and will be adding a 7.1 or 7.2 home theatre system. One constraint is the speakers have to be in wall (yes, wife). After some research i have narrowed it to these for the LCR's:
Klipsch: R-5502 (2 5.25" woofers) or KL-6502 (THX sekect 2 rated, also 2 5.25" woofers),
or
Yamaha: NS-IW660 (1 6.5" woofer) or NS-IW960 (2 6.5" woofers).
or
Definitive Tech: DI 6.5 LCR (2 6.5" wfrs) or DI 5.5 LCR (2 5.25" wfrs)
System will be on short end of a 15' by 30' room with only 7' cielings so I'm afraid the THX is overkill (and expensive). I'll also have 1 or 2 subs and probably in cieling surrounds, all powered by something like a Yamaha Aventage RX-A720 or the like. I'll choose the surrounds based on the LCR's. The wall they will be installed into is open on the other side (closet) so i have room to be creative if need be. Walls are 2x4 frame and drywall.
Biggest problem is there is no place left anymore to go and hear all these so I really need advice. Open to any and all input, but please don't challenge the use of in-wall speakers. Been there, lost that.
Quality of sound is more important to us than massive bass crank-ups. I like to hear the sound of the guitar pick running along the cable string if you know what i mean. Highs are important as most of the stuff I've seen sound muddy to me.
Thanks guys.
FidelityIsKing is offline
Reply Speakers
