Is this speaker suppose to be like this? - AVS Forum | Home Theater Discussions And Reviews
Old 11-24-2012, 01:14 PM - Thread Starter
cyyoung749's Avatar
Hi guys, i bought kef q300 speakers from ebay recently, and im just suspicious about this speaker. I bought it for 500 dollars which is 150 dollars cheaper than any sellers so i checked the corners or fingerprints just to be sure everthing is factory sealed condition like the seller said. Everything looks good except one thing. Theres is subwoofer hole on the speaker and when i checked inside with flashlight there is some kind of foam inside and i dont think this should be here. Can you tell me what this is? I cant even connect my speaker to amp or dac because its arriving next week. Thank you.
cyyoung749 is offline
Old 11-24-2012, 01:18 PM - Thread Starter
cyyoung749's Avatar
This is like this for both speakers, i just checked my logitech z-2300 subwoofer and theres no foam inside just clean.
Old 11-24-2012, 01:23 PM
Hillbilly Bill's Avatar
It actually looks like an optical illusion. Like the baffle is taking a 90 degree turn.
Hillbilly Bill is offline
Old 11-24-2012, 01:25 PM - Thread Starter
cyyoung749's Avatar
sir what you mean by rubber foot sir? This is some kind of foam is pretty big it almost blocks the whole woofer for both speakers.
Old 11-24-2012, 01:26 PM - Thread Starter
cyyoung749's Avatar
Its pretty much blocking the whole subwoofer for both speakers. Im not sure what this is
Old 11-24-2012, 01:41 PM
Please disregard my rubber foot comment, when I looked at the port it looked like there was something inside. I wasn't seeing it properly. I now see what you are referring to.
Bill Fitzmaurice's Avatar
Liked: 4972
It's damping. Perfectly normal, though it's not blocking a subwoofer, it's blocking the port duct.
There should be.
Bill Fitzmaurice is offline
