Big powerful speakers right on hardwood floor - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-25-2012, 05:19 AM - Thread Starter
pleh4help's Avatar
Hi
when I crank it up beyond reasonable (once in a while:p), if the music has sharp bass chords or bass drum, I hear a definite thump coming from the floor (I think)
Also, some very low frequency synthetizer notes will literrally shake the whole house down
I beleive the speakers or sub or both are litterally banging the floor.
When I purchased those speakers, they came with heavy duty rug spikes one could install (if room had rug, mine didn't), so I didn't install those
Speakers are all direct on a hardwood floor, And the metal mounting plates under the speakers (for rug spikes) are whats touching the wood floor first
Is there something I should put between the speaker & the floor to dampen the thumping.
I was thinking rubber foam, or even hard rubber mats, but maybe there are other ideas out there
I also saw in the speakers instruction sheets I have a place at the bottom where I could pour sand
Hesitant to go that way as they already weigh a ton
My setup:
TV: Samsung plasma 59" pn59d550, DVR: Cisco 8642HD, HTPC: Acer Aspire E1-570,
Peachtree audio DAC-iT, Logitech Harmony 650 remote, Logitech MediaBoard Pro Bluetooth k/b
Receiver: Harman Kardon HK 3490, Speakers: Mission m34i + Mission MS10 sub, Nexus 7 2nd gen
pleh4help is offline
post #2 of 6 Old 11-25-2012, 05:56 AM
BobL's Avatar
Liked: 56
If your speakers aren't too big or heavy you could use these.
http://www.auralex.com/sound_isolation_mopad/sound_isolation_mopad.asp
Bigger ones you could use one of these.
http://www.auralex.com/sound_isolation_subdude/subdude.asp
http://www.auralex.com/sound_isolation_gramma/sound_isolation_gramma.asp
Or you can make something similar yourself. But keeping it from directly coupling with the floor will probably help.
BobL is offline
post #3 of 6 Old 11-25-2012, 06:37 AM - Thread Starter
pleh4help's Avatar
Interesting!
Thanks, I will definetly look into those
One other question: As my sub is facing downward on the floor, I am therefore lead to beleive a full size mat wouldnt be recommended
My setup:
post #4 of 6 Old 11-25-2012, 07:25 AM
Bill Fitzmaurice's Avatar
Liked: 4630
Originally Posted by pleh4help View Post
Hi
That's caused by the house resonating in response to the acoustic output of the sub. The cure: turn it down.
Only if their construction is so flimsy as to make them defective.
When the floor vibrates in resonance with the acoustic output of the sub it can transfer some of that vibration back to the sub.
A piece of carpet or carpet padding will do. If you want to go really high tech buy one of these and cut pieces out of it:
http://www.walmart.com/ip/Stansport-Pack-Lite-Camping-Pad/9856753
It will make no difference whatsoever. Fourteen to forty foot long wavelengths aren't affected by a mat, or anything else for that matter.
Bill Fitzmaurice is offline
post #5 of 6 Old 11-25-2012, 07:26 AM
BobL's Avatar
Liked: 56
I'm not sure what you mean by downward facing on the floor? Is it a down firing sub? Is it a regular sub you turned on its side to place the driver facing the floor? If it is a downward firing sub one of the sub pads or gramma pads if it is larger would help as well.
BobL is offline
post #6 of 6 Old 11-25-2012, 07:37 AM - Thread Starter
pleh4help's Avatar
Yes, by design, my sub can be set to fire either down or to the side
My setup:
Reply Speakers
