help with unusual shaped room - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 11-26-2012, 06:16 PM - Thread Starter
MichLT's Avatar
We are under renovation and want to add surround sound to our living room with a sloped roof line. It goes from a low of 8ft to a high of 16 ft. How, if at all, will this type of angled roof affect surround? How many speakers should we get and suggested placement is much appreciated. We are ok with either wall-mount, in-wall and/or in-ceiling installation. We have access to installing in the roof as there are can lights already mounted and we have everything open. Here is a sketchup of the room. A 65" TV will be mounted over the fireplace. The room is roughly 24ft x 27 ft. The empty room with the lower ceilings behind the beams is a kitchen. Thanks for your advice. Budget between 1 and 2K.
Michelle
MichLT is offline
Reply Speakers
