Need advice for a 7.2 speaker selection for dedicated home theater room basement - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-26-2012, 07:39 PM - Thread Starter
sarvic's Avatar
I'm planning on getting my basement finished and decided to put a dedicated home theater room in the plans.
The dimensions are 15' 6" W x 21' 3" L x 8' 5" H
Listening preference will be 80% movies, 20 % music
I want to get the room prewired for a 7.2 speaker setup but was wondering what you would recommend for speakers in each.
The speakers would be slowly bought first and then the electronics (TV, receiver, DAC, maybe preamp) the following year.
Debating on the RTi's or the LSi M's
If I had to get the electronics right now, it would be something like this:
Recever: Denon AVR-3313CI, Marantz SR7005 or Denon AVR-4520CI or Marantz SR7007
DAC: Peachtree Nova125 or Peachtree iNova
Amplifier (optional): Emotiva XPS-2 or XPS-3
RTi Speakers
Fronts: RTi A3 or RTi
Center: CSi A6
Surround: FXi A6
Rear Surround: ???
Subwoofers (2): ???
LSi M Speakers
Fronts: LSi M 703
Center: LSi M 706c
Surround: LSi M 702 f/x
Rear Surround: ???
Subwoofers ([2): ???
sarvic is offline
post #2 of 5 Old 11-26-2012, 09:35 PM
Zophael's Avatar
For a sub, I'd go with the VTF-1 MK2 from Hsu Research. It's got plenty of power to fill a room of that size and can be tweaked to your liking. In fact, get two of them.
Zophael is offline
post #3 of 5 Old 11-26-2012, 10:04 PM - Thread Starter
sarvic's Avatar
Do you know what LSi M back surrounds would go good in that setup?
sarvic is offline
post #4 of 5 Old 11-26-2012, 10:10 PM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
HTD!
GusGus748s is online now
post #5 of 5 Old 11-26-2012, 10:46 PM
Geoff4RFC's Avatar
Quoted: 317 Post(s)
Liked: 1573
Don't even consider rear surrounds. Maybe consider wides instead. Why you ask? Good question, not only do you widen your sound stage, you increase your sound in your front stage. My room was close to yours at 15.5 wide and accommodated four RTiA9's and a pair of Epic Empires. I have both the XPA2 and 3, my FXiA6's were fed by my AVR, check it.
Spinning the rear tire at 150mph while at 3/4 lean angle will put wrinkles in your seat
Set up:
Integra 70.4--Oppo 103--LG50"Plasma--Emotiva: XPA-3, XPA-2 x 2--PolkAudio: RTiA9 x 4--CSiA6--FXiA6 x 4--Epik: Empire x 2--XBOX 360--Furez 10awg homemade cables
Geoff4RFC is offline
Reply Speakers
