Klipsch ksb 1 vs Pioneer SP-BS41-LR - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-26-2012, 09:58 PM - Thread Starter
taylord22's Avatar
Hey all,
Currently, I have a couple of KSB 1's as my fronts, a loose Energy take center channel (purchased from ebay away from its set), a couple of polk RM7s for my rears, and an energy s10.3 sub...all ran through a pioneer vsx 1021k
My question is two fold: I was thinking about upgrading my fronts to some PIONEER SP-BS41-LR...based on the review I read at thewirecutter.com...however, i was wondering how much of an upgrade they would be. I'm looking for something with a bit more low-end.
If that's not worth upgrading, would it be worth jumping on the energy take 5 speaker package that's $150 right now in order to round out a complete energy set-up?
I'm looking to stay around 100-200 right now, so maybe I should hold off and upgrade to some more substantial fronts in the future? The only problem there is that I have zero room to put anything larger than a bookshelf sized speaker (fireplace on one half of the wall, built in shelves + 65"st50 on the other).
Any guidance would be appreciated.
taylord22 is offline
post #2 of 6 Old 11-26-2012, 10:14 PM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
HTD Level 2 bookshelf speakers $200 a pair would be a nice upgrade. However, I don't understand your "low end"? You mean as in bass wise? If that's the case you will need a sub. bookshelf speakers usually do not have much bass.
GusGus748s is offline
post #3 of 6 Old 11-26-2012, 10:16 PM - Thread Starter
taylord22's Avatar
Thanks, I'll take a look. Yeah, I meant bass, but even more specifically, it just seems like my fronts are a bit too treble-y.
I do have a sub, the energy s10.3, which is probably the piece I'm most pleased with in my set-up.
post #4 of 6 Old 11-26-2012, 10:20 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
The Level Two will be more smooth.
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #5 of 6 Old 11-26-2012, 10:36 PM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
Agree. They are smooth, detailed and cleared. A friend of mine bought a 5.1 set up of the level 3, and they are awesome. My monitor 70's with RW-12D sub sound awesome, but HTD sounds with more clarity and detail. Once I buy a new house I am definitely replacing my current set up with HTDs.
post #6 of 6 Old 11-26-2012, 10:48 PM - Thread Starter
taylord22's Avatar
Great, two votes for those on here seems like a fairly resounding endorsement. Thanks guys.
Reply Speakers
Pioneer Sp Bs41 Lr 130 Watt Rms 2 Way Speaker
