Help choosing center speaker - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-27-2012, 01:42 AM - Thread Starter
omnimoeish's Avatar
Hi. I don't post much here, but I know this is the place to come for help in this type of quest.
Here's my current set up...
I have a pair of these JBL XPL 140s for my front speakers. They are probably pretty obscure. Apparently they were quite expensive back in the day.
http://www.lansingheritage.org/html/jbl/specs/home-speakers/1989-xpl.htm
http://www.lansingheritage.org/images/jbl/specs/home-speakers/1989-xpl/page16.jpg
Receiver: Harman Kardon 3600 7.1.
http://www.harmankardon.com/en-us/products/pages/productdetails.aspx?pid=avr%203600
I have a 46" Samsung LCD. It's mostly going to be used for home theater. The room is 8x8 meters.
I'm looking to get one of the bang for your buck center speakers. Here's what I'm considering. Since I've heard it's a good idea to stick with the same brand, I found a highly rated JBL center speaker.
The JBL-LC1. It sounds like even though they're 20 years newer, they still use titanium drivers.
http://www.amazon.com/JBL-LC1-Performance-Channel-Loudspeaker/dp/B000LRA6TM/ref=cm_cr_pr_product_top
I've also heard great reviews for the BIC center speakers.
http://www.amazon.com/BIC-Acoustech-PL-26-Center-Speaker/dp/B001VIRVOI/ref=cm_cr_pr_product_top
For $20 more I can get the 8" BIC although I don't know if the sound will be that much better. I really want a good center speaker though as I know it's the most critical part of a home theater.
http://www.ebay.com/itm/BIC-Acoustech-PL-28-Center-Channel-Speaker-Brand-New-/390428308083?pt=Speakers_Subwoofers&hash=item5ae7573273
A guy in my area is selling this.
http://salem.craigslist.org/ele/3419541780.html
What do you guys think? Is there anything you'd recommend? My price range is $150-$250.
omnimoeish is offline
post #2 of 4 Old 11-27-2012, 05:41 AM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
I would go with the JBL LC2 center over the LC1, its a much better speaker.
Custom, one of a kind pair, MJC212 mains, mod PT800 center, PT800 surrounds, SUB1500s. Parasound P7, Citation 19, Parasound HCA2205A, HK AVR3600, Marantz TT, Samsung BD player, Denon DVD-A player, MacBook Pro w/ Dirac Stereo Suite.
4DHD is offline
post #3 of 4 Old 11-27-2012, 05:57 AM
Elihawk's Avatar
Quoted: 1340 Post(s)
Liked: 1172
If you have JBLs as your front L/R...then you should get a the same model/make of JBL center speaker. Your front stage will then timbre match and it won't sound abit off as sound moves across the front stage!
Set up #1: EMP e5Ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, SVS NSD SB12 sub, Marantz Slimeline 1504 AV receiver
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and EMPtek10i10i sub, Denon 1910 AV receiver
Set up #3: Philharmonics- BMR in a 2.0 system, music only, Yamaha RXV-363 AV receiver
Elihawk is offline
post #4 of 4 Old 11-27-2012, 06:15 AM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 569
One of the best center speakers I have heard is the Cambridge Audio S50, which runs $200.
commsysman is offline
Reply Speakers
