14x16 room... 900 dollar budget... for speakers... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 11-27-2012, 05:45 AM - Thread Starter
chrisf695's Avatar
Quoted: 48 Post(s)
Liked: 33
I am looking for help on which 5.1 system to buy for my family room. Kinda limited on space but wondering if i can get by with satellite speakers or what system would best fit this room. I have vaulted ceilings with a hardwood floor. Listen to 70% movies and 30% TV.
Thanks for you suggestions.
chrisf695 is offline
post #2 of 10 Old 11-27-2012, 06:22 AM
commsysman's Avatar
Quoted: 767 Post(s)
Liked: 462
I would suggest that you consider a set of KEF speakers.
I have owned them and they are hard to beat in that price range.
At KEF Direct they have the C3 speakers for $329; those could be your front speakers.
The C1, at $279, would be the rear speakers, and a C6 LCR center speaker runs $270.
KEF has been one or Britain's top speaker manufacturers for over 50 years; they make very good speakers.
A subwoofer would be additional, of course. Amazon has the Polk Audio PSW505 for only $189 at present, which is a heck of a deal.
For your room you definitely want a 12-inch sub with over 200 watts RMS, and most good ones are over $500. The PSW505 is probably the best you can get at this time with your budget, and it's not too bad.
commsysman is offline
post #3 of 10 Old 11-27-2012, 07:31 AM - Thread Starter
chrisf695's Avatar
Quoted: 48 Post(s)
Liked: 33
How do you feel about the ProCinema 800 series? Would that deliver the same punch as the KEF setup? Thanks for the reply, the KEF setup sounds very interesting.
post #4 of 10 Old 11-27-2012, 07:33 AM
ousooner2's Avatar
Quoted: 240 Post(s)
Liked: 145
By limited space do you mean you want/need bookshelves up front or are towers still an option?
Also, do you want to spend $900 max or do you mind building a little bit over time and spending more than that? Still good options if you only wanted to spend a max of $900 on a 5.0/5.1.
You missed out of the EMP deal....that sucks. What looks like a very nice 5.0 for under $900. I'll be reviewing mine when I get it
Panny 65st60 / Denon X1000 / EMP e55ti / EMP e56ci / EMP e5bi / (2) e1010i
ousooner2 is offline
post #5 of 10 Old 11-27-2012, 07:44 AM - Thread Starter
chrisf695's Avatar
Quoted: 48 Post(s)
Liked: 33
Well right now i have b&w 684 for my fronts and the htm62 for a center and thats it. I have a buyer tonight coming to pick this system up for 900. I would like to just jump into a 5.1 system and be done with it. I thought i would do the same thing with my b&w setup with adding over time... but funds were never there to do that.
post #6 of 10 Old 11-27-2012, 08:47 AM
zieglj01's Avatar
Quoted: 925 Post(s)
Liked: 836
How much bass response are you looking for - and are you looking for
satellite type speakers, or do you want bookshelves?
__________________________________________
Who AM I
Speakers > MB Quart VS05, Boston VS260, Snell K7, EOS 150SP
Subwoofer > Mordaunt Short Aviano 7
Receiver > Tascam PAR-200, Pioneer VSX-30
zieglj01 is online now
post #7 of 10 Old 11-27-2012, 08:58 AM - Thread Starter
chrisf695's Avatar
Quoted: 48 Post(s)
Liked: 33
How much of a performance difference is there between them? I want whatever has the best performance for the buck. I found the Procinema 800 for $800 bucks. But the KEF C1 5.1 package looks also really good too.
paradigm 5.1 ct 100 also.... that compare with these systems?
http://www.ebay.com/itm/221095078109?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
http://www.ebay.com/itm/Definitive-Technology-ProCinema-800-Speaker-System-/221156940170?pt=Speakers_Subwoofers&hash=item337dfb198a
post #8 of 10 Old 11-27-2012, 09:52 AM
zieglj01's Avatar
Quoted: 925 Post(s)
Liked: 836
In general, bookshelf speakers with bigger woofers, bring better bass performace and
tend to go lower for an easier crossover to the sub.
The KEF looks decent, so to speak - not drawn to their sub
Definitive Tech and Paradigm can be nice.
If I needed to do a sub/sat system, I would lean towards the Acoustic Energy set from AC4L.
Acoustic Energy makes some well designed and engineered speakers. >> Their dual 8" sub
looks nice for a subwoofer that size, and seems to be heavy and well built. >> That system
use to sell for a list price of around $2000.
http://www.accessories4less.com/make-a-store/brand/ACOUSTIC+ENERGY/results/1.html
With that said, I would aim for a bigger system - if you can fit it. Also go to HTD.com and
look at their Level Two speakers - however, there are some better sub options around. >
It depends on how much bass you want.
http://www.htd.com/Products/level-two-speakers
Who AM I
post #9 of 10 Old 11-27-2012, 01:44 PM
Kini62's Avatar
Quoted: 1109 Post(s)
Liked: 1020
5 NHT Superzero 2.0s and a SV Sound PB1000. That's $1K total. Just over your budget. You can get to $900 if you maybe go with the Pioneer speakers have more money for a bigger sub.
http://www.amazon.com/Pioneer-SP-BS22-LR-Designed-Bookshelf-Loudspeakers/dp/B008NCD2LG/ref=sr_1_fkmr0_1?s=electronics&ie=UTF8&qid=1354052589&sr=1-1-fkmr0&keywords=pioneer+sp-bs22-lr+bookshelf+loudspeakers+pair
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is online now
post #10 of 10 Old 11-28-2012, 01:02 AM
GusGus748s's Avatar
Quoted: 386 Post(s)
Liked: 694
HTD level 2 bookshelf $199.00
HTD level 2 center $129.00
HTD level 2 sub $349.00
HTD level 2 surround $129 X 2 = $258
Total: $935.00 does not include shipping.
Or you can substitute the surround sound speakers for satellite speakers, which would bring the price down.
GusGus748s is offline
Reply Speakers
