Need a low profile/thin center channel please - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-27-2012, 09:20 AM - Thread Starter
virii01's Avatar
After replacing my Sony projection TV with a plasma, I realized that my old center channel can no longer sit on top of my TV tongue.gif
I have a spot for a CC under the TV but it needs to be relatively thin. My max height is about 4 3/4".
Can anyone recommend a lower profile center channel for ~$150? It's replacing a B&W CC3. The rest of the speakers are older Infinity towers with soft tweeters. I realize I won't get a perfect match but hopefully I can find something decent for clear dialogue in that price point. Thanks
virii01 is offline
post #2 of 5 Old 11-28-2012, 09:47 AM - Thread Starter
virii01's Avatar
Any suggestions at all? I know ideally I'd make room for a traditionally sized CC but unfortunately it's not an option. I'm really just looking for a decent CC that's less than 5" tall and $<150-200. Thanks
virii01 is offline
post #3 of 5 Old 11-28-2012, 02:08 PM
Kini62's Avatar
Quoted: 1410 Post(s)
Liked: 1292
There's this- http://www.crutchfield.com/p_769CSB1210/Center-Stage-Bracket-CSB-1210-BLK.html and you won't need to buy a cheap center that doesn't match up with your other speakers.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #4 of 5 Old 11-29-2012, 01:16 PM
Phase700B's Avatar
Liked: 25
That is an interesting bracket. However, it may void a TV warranty because of the pressure it would place on the bezel of the TV screen. Such pressure can and does cause uneven pressure on the edge of the LCD or plasma panel and may cause light leakage from the back lights or other damage to a plasma panel.
Some center channel speakers like my Infinity CC-2 weigh in at almost 22lbs. Many CC speakers are made rather heavy to dampen internal vibrations and resonance for optimum sound quality. I've seen some CC speakers run close to 30 lbs. I have my 46" LCD nestled in an oak TV ensemble with a "bridged": shelf between two side towers that have shelves. The wooden bridge is 2" thick but needs a center support to keep the CC speaker from warping it.
xsists likes this.
Phase700B is offline
post #5 of 5 Old 11-29-2012, 02:24 PM
Kini62's Avatar
Liked: 1292
Says it's designed for speakers up to 25#. Plus it spreads the force out over 12" and much of the weight seems to be supported by the "brackets" in the back.
Even with some caveats it seems a better solution than buying a tiny center speaker that does not match the rest of your system.
But here is a slim, short speaker worth considering-
http://www.amazon.com/Yamaha-NS-C310BL-Bass-Reflex-Center-Speaker/dp/B001PZ674C/ref=sr_1_1?ie=UTF8&qid=1354224214&sr=8-1&keywords=yamaha+ns-c310
Def Tech SC8000
Kini62 is offline
Reply Speakers
