Suggestion for Surround and Subwoofer: under $400 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-27-2012, 03:02 PM - Thread Starter
anon812's Avatar
Hi All,
I would like to setup a decent 7.1 system, and have already purchased Front L and Front R (Polk Monitor 70 series) and Center Channel (CS2). My Receiver is Marantz 5007..
Given these, need expert's suggestions for a decent Subwoofer and surround speakers. Does the quality of Surround speakers really matter or should it matter? This is part of my media room(Movies and music) setup..any wisdom much appreciated.
Other info: this is an enclosed media room in the second floor, not sure if floor firing subs will be a good idea..but wanted to give this piece of info!
anon812 is offline
post #2 of 4 Old 11-27-2012, 07:02 PM - Thread Starter
anon812's Avatar
Wow ...12 views and 0 replies...I see PSW505 and BIC F12 listed under $200 should I bite into one of them? there is enough 505 vs f12 but there is no final verdict, wish there was a sticky about this. Any thoughts much appreciated for a Subwoofer to start with and i will spend the rest on surround sound.
anon812 is offline
post #3 of 4 Old 11-27-2012, 07:14 PM
Sonyad's Avatar
Quoted: 194 Post(s)
Liked: 111
Post in the subwoofer forum for more info. There is a thread there about low budget subwoofers.
Sonyad is offline
post #4 of 4 Old 11-27-2012, 11:10 PM
afrogt's Avatar
Quoted: 1435 Post(s)
Liked: 982
get some Monitor 30's as surrounds then you can spend more on a subwoofer.
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290200
Afro GT
afrogt is offline
Reply Speakers
