bi-amping a bi-wire speaker - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 11-27-2012, 06:56 PM - Thread Starter
brucegn's Avatar
Hello,
I am seriously considering the Ascend CMT 340se speakers for my HT. I like that they seem very efficient and can take quite a bit of power. But, I noticed that the speakers are bi-wireable and not bi-ampable. I know what each term means, but what would happen if someone bi-amped a speaker that was meant to be bi-wired only? Thanks...
Bruce
brucegn is offline
post #2 of 14 Old 11-27-2012, 07:35 PM
duc135's Avatar
Quoted: 155 Post(s)
Liked: 220
Correct me if I'm wrong, but a speaker with dual binding posts connected via a jumper plate/wire can be both bi-amped or bi-wired. The jumper plate merely provides and external connection between the internal crossover sections. The crossover and speaker does not know the difference whether it has been bi-amped or bi-wired. So the answer to your question would be that nothing would happen.
duc135 is offline
post #3 of 14 Old 11-27-2012, 07:38 PM
ccotenj's Avatar
Liked: 101
you are correct...
neither option accomplishes anything though...
- chris
ccotenj is offline
post #4 of 14 Old 11-27-2012, 07:40 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
Here's the Ascend designer's take http://forum.ascendacoustics.com/showpost.php?p=32217&postcount=4
Do you truly have separate amps to make this even somewhat interesting? Do you have the desire to open the speaker and truly bi-amp these speakers and have the electronics to carry it out?
lovinthehd is offline
post #5 of 14 Old 11-27-2012, 07:49 PM - Thread Starter
brucegn's Avatar
No, I have a 7.1 receiver with 140W/ch. It's a Pioneer SC-27. I am presently bi-amping my speakers using the rear surrounds as the power to the upper binding posts. I don't have the speakers yet, but, it was truly doable and would make a difference in performance then I would be open to trying it.
brucegn is offline
post #6 of 14 Old 11-27-2012, 07:51 PM - Thread Starter
brucegn's Avatar
By-the-way, the article answered the question pretty well. Thanks for the link!
brucegn is offline
post #7 of 14 Old 11-27-2012, 07:52 PM
lovinthehd's Avatar
Liked: 4775
Personally I'd say your wasting your time thinking your avr can bi-amp at all. Some avrs have the circuitry to truly do it, but that's not one of them afaik. Without truly separate amps I don't think you'll hear an advantage unless you convince yourself you are by doing so...
post #8 of 14 Old 11-27-2012, 07:58 PM - Thread Starter
brucegn's Avatar
Interesting...I have thought about taking the plunge and getting one the the emotive amps, but I have yet to work up the funds to do so. So, I think for now I will connect my future speakers to the lower binding posts and just use the metal connector plates to the top...thanks for the info. BTW, what is afaik?
brucegn is offline
post #9 of 14 Old 11-27-2012, 08:27 PM
Bill Fitzmaurice's Avatar
Liked: 4706
There would be some improvement, by reducing intermodulation distortion via separately amplifying the highs and lows. But unless you bypass the internal passive crossover you wouldn't get the full benefit.
Bill Fitzmaurice is offline
post #10 of 14 Old 11-27-2012, 08:31 PM
lovinthehd's Avatar
Liked: 4775
afaik-as far as I know
Bill is a speaker designer, haven't heard that about IMD before, so maybe even with an avr amp this is something?
post #11 of 14 Old 11-27-2012, 08:36 PM - Thread Starter
brucegn's Avatar
Thanks for the info. If I get those speakers I'll try hooking up 3 different ways to see which sounds best...single wire, bi-wire and bi-amp.
brucegn is offline
post #12 of 14 Old 11-27-2012, 08:40 PM
Liked: 4706
It depends on the AVR of course, it must have a true electronic crossover. The main source of IMD is when the amp is pushing hard on the lows, which impacts it's ability to cleanly deliver the highs. The worst case scenario is when the amp starts to clip, which gives not only high level IMD but also high level THD. If you bi-amp both conditions are alleviated, especially the potentially tweeter destroying THD. The low frequency amp may still clip, but the resulting increased power density in the harmonics won't bother woofers.
post #13 of 14 Old 11-28-2012, 04:07 AM
ckartson's Avatar
I have an intergra DTR 40.2 that allows the option of bi amping the front left and right speakers. The trade off is 7.1 is not available any more. I did try biamping my front speakers BW 906 I think, and there is a difference in sound primarily for music. I like the sound and left it that way. It doesn't seem to make much of a diff for movies and I have been using the system as 5.1 any way. To me the most difference seems to be a depth to drum beats. I have a nice Matrin Logan sub woofer but I am not a fanatic and it is not shake the walls. It just seems to add depth to drums. Just my two cents.
ckartson is offline
post #14 of 14 Old 12-01-2012, 09:52 AM - Thread Starter
brucegn's Avatar
Thanks for all the comments, truly appreciated.
brucegn is offline
Reply Speakers
