How to budget a 5.1 Speaker System - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 11-27-2012, 08:07 PM - Thread Starter
Kryptos19's Avatar
I'm looking into building a home theater system and was curious how I should go about budgeting for the speakers and sub. I'm thinking of building around an Onkyo TX-NR616 receiver but doubt I'll be able to do it all at once. If I was to build a system, in what order would it be best to pick up new speakers/sub and about how much money (based on an overall %) would be a good way to invest money?
IE
100% Total System
50% Receiver
20% Sub
15% Center
10% Front Main Speakers
5% Back Speakers
Thanks for any insight that can be offered.
Kryptos19 is offline
post #2 of 12 Old 11-27-2012, 08:22 PM
rick240's Avatar
Quoted: 28 Post(s)
Liked: 53
It will of course vary based on deals that you find, but I would say:
- 25% receiver
- 25% sub
- 50% for the 5.0
I got a great deal on my speakers, so my system was:
- 33 1/3% receiver
- 33 1/3% sub
- 33 1/3% speakers
Key takeaway, you're planning way too much on the receiver and not enough on the speakers. Speakers make the most difference; buy last year's receiver on clearance and save a bundle.
rick240 is offline
post #3 of 12 Old 11-27-2012, 08:25 PM - Thread Starter
Kryptos19's Avatar
50% was really just an example. I have no idea how it should be budgeted against everything else.
Any idea how I should budget my speakers within that 33% (or 50%)?
post #4 of 12 Old 11-27-2012, 08:30 PM
rick240's Avatar
Quoted: 28 Post(s)
Liked: 53
Do you ever listen to multi-channel music? If so the rears become more important than in HT only.
Will your space allow you to put 3 identical speakers across the front? If you can, you should - and that would have your centre costing 50% of your mains not 150% as in your first cut. If you can't, then unfortunately the compromise horizontal centres that most people get cost proportionately more, but still shouldn't cost more than the front pair.
rick240 is offline
post #5 of 12 Old 11-27-2012, 10:48 PM
Knucklehead90's Avatar
Quoted: 504 Post(s)
Liked: 435
RULE OF THUMB: - when it comes to buying speakers for HT or stereo - doesn't matter - spend as much as you can on speakers. Buy them one at a time if you have to. The best receiver in the world will sound like crap with crap speakers. Good speakers will make all but the very cheapest receiver sound like gold.
Yamaha CX-A5000 - VTA ST-120 (6550 output tubes) - Salk Song Towers - Oppo 103
Vinyl Room: Emotiva PT-100 - Acurus A100 amp - Acoustic Research AR-2ax - Marantz TT42 - Oppo 103
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is online now
post #6 of 12 Old 11-28-2012, 12:47 AM
GusGus748s's Avatar
Quoted: 428 Post(s)
Liked: 705
I agree. Buy the best 3.1 set up you can, and then decide on a receiver.
GusGus748s is online now
post #7 of 12 Old 11-28-2012, 11:36 AM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1352
On a tight budget, I would say get 2.0.
shadyJ is offline
post #8 of 12 Old 11-29-2012, 09:30 PM
wes182's Avatar
Quoted: 54 Post(s)
I would agree on speakers first and then go from there.
wes182 is offline
post #9 of 12 Old 11-29-2012, 11:40 PM
GusGus748s's Avatar
Quoted: 428 Post(s)
Liked: 705
That will depend on your budget. You want the best speakers that you can afford.
post #10 of 12 Old 11-30-2012, 12:03 AM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4783
Can't budget on percentages alone, need $$ amounts here. And it's not an investment except in your own pleasure...not much of a way to invest money.
lovinthehd is offline
post #11 of 12 Old 11-30-2012, 09:18 PM
justindo's Avatar
It really depends on your budget. For example, if your budget is $500, a decent budget A/V receiver will eat up at least a third to more than half of that amount. On the other hand, if you're looking at a $5,000 system, a $500 receiver might be all you need to spend if your speakers aren't too difficult to drive. Generally, my rule of thumb is that the three front speakers are the most important, followed a great distance by the sub, then closely by the receiver (amp and then preamp if you're talking separates), and then the rears. Cables would be last, but in a budget system they would occupy a much higher percentage than in a more expensive one.
Don't discount a 2.0, 2.1, 3.0, or 3.1 system if you're on a budget; two good speakers are better than 5.1 lousy ones.
nlpearman likes this.
justindo is offline
post #12 of 12 Old 11-30-2012, 10:58 PM
lespurgeon's Avatar
Quoted: 31 Post(s)
Liked: 52
60% fronts 40% receiver
lespurgeon is offline
Reply Speakers
