**Need Help** Newbie Needs Assistance with Speaker Options - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 11-28-2012, 12:26 AM - Thread Starter
pooriepoorie's Avatar
Folks,
I am a newbie, do not understand acoustics principles much, and hence this post requesting you experts to help out. I am looking to start building a HT system (with a starting budget of $1500), and slowly add on. My living room is 16X21X8 ft and backs up to a dining area 12X12 ft through a 4 ft wide passage. Primary usage will be for movies and music. No gaming.
Based on what I have read across different forums, here are the options that I see for myself:
OPTION 1
- 2X Ascend CBM SE 170 (Fronts): $300
- Ascend CMT 340 SE (Center): $ 300
- No surrounds to start off with (plan to eventually get 2X340s for fronts and use the 170s that I buy now as surrounds)
- HSU VTF 2 MK4 Sub: $520
- Denon AVR 1712: $400
Total Cost: $1,520
OPTION 2
- 2X Infinity Primus p163 (Fronts): $170
- Infinity primus c351 (Center): $275
- 2X Infinity Primus p143 (Surrounds) = $120
Total Cost: $1,485
OPTION 3
HSU Hybrid Package 2 ($1,260)
- 1 VTF-2 MK4 Subwoofer
- 4 HB-1 MK2 Horn Bookshelf Speakers
- 1 HC-1 MK2 Horn Center Channel speaker
Total Cost: $1,660
OPTION 4 (In case we go over the Fiscal Cliff )
- Energy Take Classic 5.1: $300
Total Cost: $700
I would request you folks to weigh in on these options and guide me through this purchase. I appreciate your comments in advance
pooriepoorie is offline
post #2 of 14 Old 11-28-2012, 01:46 AM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
I would suggest to buy the best 3.1 set up you can afford and AVR. I would go with HTD level 3 front towers, lever 3 center and lever 3 sub. Thereafter, whatever AVR you can afford.
GusGus748s is offline
post #3 of 14 Old 11-28-2012, 06:06 AM
Elihawk's Avatar
Quoted: 1014 Post(s)
Liked: 856
Option one would give you a GREAT system (when complete)! Those Ascend 340s are a top shelf speaker for the money!
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is offline
post #4 of 14 Old 11-28-2012, 02:20 PM
smasher50's Avatar
Quoted: 354 Post(s)
Liked: 15598
fwiw, all the options are good ones including the htd level3 's you could not go wrong with any one of them but i would opt for the ascends route myself good luck
i'm so laid back,i'm laid out
smasher50 is online now
post #5 of 14 Old 11-28-2012, 05:54 PM - Thread Starter
Thanks guys!
Quick question – how credible is an arrangement to use the CBM 170 for both the fronts and surrounds? I would ideally like to mount the sorrounds on the wall and I read somewhere that 170s may not be the best choice as mounted speakers. I wanted to understand the options that I have.
Thanks again!
post #6 of 14 Old 11-28-2012, 06:21 PM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
Originally Posted by pooriepoorie View Post
Thanks guys!
Thanks again!
The CBM 170 is a rear ported speaker, therefore you can not place them on a wall. They would need at least 6" clearance in back. The fact they say they are wall mountable, is laughable. Unless that port is plugged and then that changes everything the speaker is.
Custom, one of a kind pair, MJC212 mains, mod PT800 center, PT800 surrounds, SUB1500s. Parasound P7, Citation 19, Parasound HCA2205A, HK AVR3600, Marantz TT, Samsung BD player, Denon DVD-A player, MacBook Pro w/ Dirac Stereo Suite.
4DHD is offline
post #7 of 14 Old 11-28-2012, 07:25 PM
smasher50's Avatar
Quoted: 354 Post(s)
Liked: 15598
fwiw, i think you should be fine mounting using them as surrounds with some pinpoint am 40 wall mounts these will let you tilt the speaker forward enough to give the port plenty of room.
post #8 of 14 Old 11-29-2012, 02:42 PM
flvinny521's Avatar
If you are lucky enough to be near a Best Buy with the 1712 still in stock, you can get it for $200 or less. I just bought an open box model (only missing the Audyssey mic) for less than $170. You may have to call or visit, because this particular store said it was out of stock on the website, but they actually had three.
flvinny521 is offline
post #9 of 14 Old 11-30-2012, 04:22 PM - Thread Starter
Update: I just ordered the CMT 340s for L/C/R. They are on backorder and may be delivered only in January. I may buy two HTM 200s for sorrounds in some time. Thanks all for your help!
I have a couple of more questions:
1. What should be the optimal size of the speaker stands that I should consider for the 340s? The TP 24 model available on the Ascend Acoustics website seems to be a little high for my setup and taste. I located some Sanus stands on Craigslist that are 13" tall, but I was not sure if that is enough. Any thoughts?
2. Any opinions on speaker wires? Would the RCA 16 gauge wires work well?
post #10 of 14 Old 11-30-2012, 04:25 PM
cschang's Avatar
Quoted: 107 Post(s)
Liked: 164
Optimally, for just about any speaker, the height of the tweeter should be the same height as the ears when listening.
16 gauge speaker wire should be fine unless it is a long run.
-curtis
Owner of Wavecrest Audio
Volunteer Mod at the Ascend Acoustics Forum
Like all things on the Internet, do your research, as forums have a good amount of misinformation.
Help beat breast cancer!
cschang is offline
post #11 of 14 Old 11-30-2012, 05:05 PM - Thread Starter
Curtis
In a 340, how far up is a tweeter from its base?
post #12 of 14 Old 11-30-2012, 06:14 PM
Ascend's Avatar
Quoted: 112 Post(s)
Liked: 274
Sorry, but the information you are posting is false. The CBM-170's are not only easily wall mountable, but they sound fantastic in this type of setup. About 30% of our 170 customers wall mount the speakers and that translates to a very large number when considering how many 170's have been sold.
The 170's were not designed for deep bass and the small 1.25" diameter rear port is tuned to about 55 Hz and acts a bit more like an aperiodic vent than a Helmholtz resonator, thus contributing very little to the overall output of the speaker. At only 2" - 3" clearance from the wall, the air-flow of the port tube even at loud volumes is completely unrestricted. When used with an 80Hz high pass filter (typical when used with a subwoofer) 1/2" clearance is all that is needed.
I have a pair of 170’s that I am using full range and they are placed in an entertainment center cubby hole with about 3” clearance behind each speaker. I love the way the sound in this setup.
David Fabrikant
audio professional and soft spoken representative of www.AscendAcoustics.com
Ascend is offline
post #13 of 14 Old 11-30-2012, 06:22 PM
Ascend's Avatar
Quoted: 112 Post(s)
Liked: 274
Curtis
David Fabrikant
Ascend is offline
post #14 of 14 Old 11-30-2012, 09:14 PM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
1.25" port! why bother. And you're telling me IF wall mounted they're 3" away from the wall? Glad you like 'em.
But I'll keep my high end JBLs, just the same.
4DHD is offline
Reply Speakers
