Do you think it's worth upgrading from Pioneer SP-C21 to Pioneer SP-C22? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-28-2012, 01:29 PM - Thread Starter
Stealth3si's Avatar
Quoted: 32 Post(s)
Considering the 5.1 setup below in my signature, is it a wise move or worth $19.65, to upgrade my Pioneer SP-C21 center speaker to a Pioneer SP-C22 center speaker?
5.1 small-room size: 800 ft³+ 54 ft³ corner door space
AVR: Denon 1712
Fronts: Pioneer SP-BS41-LR /Center: Pioneer SP-C21 / Rear: Pioneer SP-BS21-LR
Subwoofer: SVS PC12-NSD
Screen: Samsung UN46EH6070 46" 1080p 3D LED 240 CMR TV
Viewing distance: 7.33 ft
Stealth3si is offline
post #2 of 7 Old 12-08-2012, 07:25 AM
jdpaskall's Avatar
Irishman: Yes yes yes,,,,,,,
Originally Posted by jdpaskall
but in your next post you reply: No, unfortunately the 2011 models won't voicematch the 2012 models. Wouldn't that apply here too?
Irishman: Hmm. I thought I was saying the same thing.
At least I meant to.
Just want to clarify for all unfortunately the 2011 models won't voicematch the 2012 models. So stick with the same year model right?
jdpaskall is offline
post #3 of 7 Old 12-08-2012, 09:00 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
I've read the SP-C22 is a better sounding center but I don't think it is the tonal match for your other speakers. They made some improvements/changes to the new series.
But if its only going to cost you less than $20 why not get it and try for yourself paired with your own Pioneer speakers? $20 is pretty trivial and you'll have the answer you'll seek.
Afro GT
afrogt is offline
post #4 of 7 Old 12-08-2012, 12:42 PM - Thread Starter
Stealth3si's Avatar
Quoted: 32 Post(s)
I don't have an experienced ear to determine if they voice match.
AVR: Denon 1712
post #5 of 7 Old 12-08-2012, 10:12 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3078
Version 2 of the Andrew Jones speakers are definitely a major improvement. I'd say go for it since it's only $20. If you decide the voice matching isn't to your liking you could also upgrade your fronts at a later date.
Living Room: B&W 804D, B&W CMC S2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
postrokfan is offline
post #6 of 7 Old 12-09-2012, 12:05 PM - Thread Starter
Stealth3si's Avatar
Quoted: 32 Post(s)
what if i don't like it, then what matching front and rear speakers would match and how much they cost?
since there is a relatively small difference in price between the C22s and C21s, i'm looking at possible yet reasonable extra upgrade costs there as well.
AVR: Denon 1712
post #7 of 7 Old 12-09-2012, 02:35 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3078
There's no need to replace your rear speakers. It's most important for your front three to timbre match. If you could fit the FS-52s (mini-tower) in your setup that would be a logical upgrade. There's no version 2 of the BS41s. I suppose you could try the BS22s up front if the mini-towers aren't an option space-wise.
Reply Speakers
Pioneer Sp C21 130 Watt Rms 2 Way Speaker , Pioneer Andrew Jones Sp C22 Center Channel Speaker
