Budget tower speaker recommendations - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-28-2012, 03:22 PM - Thread Starter
abcdefghi's Avatar
Quoted: 38 Post(s)
I am looking for some budget tower speakers, but given the hundreds of different options out there, and being unable to listen to probably any more than 5-10% of them, its hard to make a choice. I have about $400 to spend on the pair, less is always better, but I know that with something like speakers, less very rarely means more. I am looking at the Energy CF-70 in the classifieds, but some of the reviews I have read on them seem to be so so.
Any recommendations? these will be used for music, but primarily as HT speakers (so it would be nice if ultimately I can get a matching center), already have a sub.
abcdefghi is offline
post #2 of 6 Old 11-28-2012, 03:48 PM
commsysman's Avatar
Quoted: 1008 Post(s)
Liked: 531
If you already have a sub, you will get much better sound quality from bookshelf/monitor speakers than from towers at a given price point.
When you buy a tower speaker, you are normally paying extra for low-frequency response that you do not need if a subwoofer is going to be in the system.
I suggest that you consider a pair of the KEF iQ10 speakers, which you can get from the KEF Direct website for only $300 now. those are very good speakers.
To get tower speakers that sound as good, you will have to spend $500 or more.
The C6LCR center speaker is a matching KEF speaker.
commsysman is offline
post #3 of 6 Old 11-28-2012, 03:49 PM
JerryLove's Avatar
Liked: 81
From my personal experience: Infinity Primus 362 or 363 (I believe Fry's has a sale for $109/ea).
From recommendations I've seen: Polk Monitor 70's
From recommendations I've seen: Pioneer (forget the model, the current tower)
JerryLove is offline
post #4 of 6 Old 11-28-2012, 03:57 PM
drunkpenguin's Avatar
Quoted: 1211 Post(s)
Liked: 1161
I'll 2nd the primus 363. good sounding speaker for a price you can't beat anywhere.
Just 'cause you're right doesn't mean I'm wrong
drunkpenguin is online now
post #5 of 6 Old 11-29-2012, 08:52 AM - Thread Starter
abcdefghi's Avatar
Quoted: 38 Post(s)
Thanks, I will look into the suggestions above. I am also not opposed to buying used, so watching the classifieds.
post #6 of 6 Old 11-29-2012, 02:08 PM
Transmaniacon's Avatar
Quoted: 1530 Post(s)
Liked: 1320
Take a look at www.audiogon.com It's a great place to find fantastic audio gear. Generally it caters to a higher budget, but sometimes you find some good deals.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
Reply Speakers
