Definitive Technology - CLR-2300 (Subwoofer Noises) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-28-2012, 04:10 PM - Thread Starter
realmike15's Avatar
My CLR 2300 recently started making popping noises. I've tried unplugging the speaker cables as well as using different power outlets, but the only way to make it stop is to unplug the power for the built-in subwoofer. If I unscrew the back and look inside, are there any suggestions on what I should be looking for? I've probably had this for 8+ years, so there's no way it's still under warranty.
realmike15 is offline
post #2 of 5 Old 11-28-2012, 04:18 PM
truwarrior22's Avatar
Quoted: 352 Post(s)
Liked: 84
Sometimes wireless routers and cell phones can cause a popping noice. Does turning the volume nob make it any better or worst? Is it a steady noise? Does it make a noise if your not playing anything? How hard do you usually drive it? If you call Def Tech they may have some replacement parts for it.
truwarrior22 is offline
post #3 of 5 Old 11-28-2012, 05:07 PM - Thread Starter
realmike15's Avatar
It's a constant noise, it happens whether its playing or not, even if I unplug the speaker cables. Volume knob has no effect on the volume of the noise. Not driven hard at all, usually played at moderate volumes with subwoofer knob around 1/2 way.
post #4 of 5 Old 12-14-2012, 10:43 AM - Thread Starter
realmike15's Avatar
I guess no one has any advice on this one...
post #5 of 5 Old 12-15-2012, 04:59 PM
zibanez's Avatar
Quoted: 36 Post(s)
why not posted in definitive thread? I'm sure Joe from Def Tech will answer or just send email to their customer service. They've good respons for costumer complaints
Bedroom theater
Dynaudio DM 2/6 - Dynaudio DM Center - Def tech pro monitor 600 - Rythmik Audio CI 15" HP600 - Marantz NR1402 - Bantam Gold Power Amp - Clark Synthesis tst 239 - Dune H1 - PS3
zibanez is offline
Reply Speakers
