B&W 600 series - Upgrade Advice - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-29-2012, 11:02 AM - Thread Starter
atomz618's Avatar
I currently have B&W 685s as front speakers powered by a Denon AVR 1611.
I'm looking to add a center channel either HTM61 or 62, and my plan was to get 686s for rears since I'm still in an apartment and didn't want towers to blow the place down. The 685s with no sub have been plenty loud for me, so that was why I thought I'd hold off on the towers for now.
1) After reading reviews for the 686s, now I'm unsure if it would make a good system with 685 as fronts and 686 as rears... Should I just go for the 684 towers?
2) Reviews for the center are also saying the smaller one is better
3) Any sub suggestions? I've heard the B&W subs over priced and that I don't need to match brands for the subs.
Any advice on this possible set up would be greatly appreciated!
atomz618 is offline
post #2 of 4 Old 11-29-2012, 03:11 PM - Thread Starter
atomz618's Avatar
Also an option would be no subwoofer... has any one tried the 5.0 setup?
atomz618 is offline
post #3 of 4 Old 11-29-2012, 07:59 PM
postrokfan's Avatar
Quoted: 525 Post(s)
Liked: 3146
The 686s should be fine for surrounds. Another 685 would be the best option for your center. Unfortunately, 685s (as you know) only come in pairs so buying another set might not be a viable option for you. If this doesn't work I'd probably go with the HTM61 (despite the relatively narrow "sweet spot"). For HT, a subwoofer will provide you with the best listening experience. I would recommend something from HSU Research, SVS, or Rhythmik. The B&W subs are decent but they're quite expensive for what you get, hence the internet direct recommendations.
Living Room: B&W 804D, B&W CMC S2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
postrokfan is offline
post #4 of 4 Old 11-29-2012, 09:13 PM
jima4a's Avatar
Quoted: 275 Post(s)
Liked: 147
I have three 685s in one system and a good choice. I have also heard the CMC2 recommended, although quite a bit more money.
Main Kef: Reference 205/2 & 202/2c, Surrounds: Kef XQ40, Velodyne Optimum 12, Integra DHC 80.3, Ayre K-5xeMP, Oppo BDP-103, Bryston 4Bsst2, Parasound Halo A31. Second B&W: 685 (3), CCM618, Def Tech Powerfield 1500, Onkyo TX-NR1008, Zone 2 Klipsch AW650.
jima4a is offline
Reply Speakers
