Screws and speakers? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-29-2012, 04:24 PM - Thread Starter
Julianv112's Avatar
Are you able to screw a speaker mount into a wooden speaker that doesn't have a mount without harming the speaker sound or anything?
Julianv112 is offline
post #2 of 7 Old 11-29-2012, 04:26 PM
afrogt's Avatar
Quoted: 1440 Post(s)
Liked: 983
Yes, if you're careful. I bought some used speakers that had the mount and 4 screws still attached. I wouldn't put screws in a little satellite speaker though.
Afro GT
afrogt is offline
post #3 of 7 Old 11-29-2012, 04:31 PM - Thread Starter
Julianv112's Avatar
Im thinking about putting them in a Polk Audio TSi 200's, what do you think?
post #4 of 7 Old 11-29-2012, 04:49 PM
Brennan.OSD's Avatar
What style speaker mounts are you planning to use on those?
- Brennan, Outdoor Speaker Depot
Brennan.OSD is offline
post #5 of 7 Old 11-29-2012, 06:19 PM - Thread Starter
Julianv112's Avatar
I was thinking of making my own speaker mounts with wood or http://www.bracketsandstands.com/PINPOINT_MOUNTS_AM10_SPEAKER_WALL_MOUNT_BRACKETS_p/am10.htm
post #6 of 7 Old 11-30-2012, 11:58 AM
I would take in a few factors. Such as the type of wood the speakers are made with (will it crack if drilled?), the depth of the wood and proximity of any internal components, and the weight capacity of the mount.
- Brennan, OSD Audio
post #7 of 7 Old 12-03-2012, 03:03 PM - Thread Starter
Julianv112's Avatar
Yea thats why im not gonna try to mess with it, its not worth testing i dont want to mess up my speakers that wouldnt be good.
Reply Speakers
