Sony 2.1 SRS D8 vs Philips CSS2123/05 Soundbar - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 11-30-2012, 11:17 AM - Thread Starter
rbmaster's Avatar
I want to buy something to hook to my Sony Bravia KDL-32EX600 on a small bedroom, with a small budget (<100€).
Sony SRS D8
Experience the high quality and powerful sound from SRS-D8 speakers, with a powerful output power of 60W, high quality digital amplifier and MDF-equipped subwoofer.
60W total output power
High quality digital amplifier
Bass reflex port sound system to boost base sounds
MDF-equipped subwoofer for clear and natural base sound
15 degree upward design for easy listening
RCA / Stereo mini jack input
Speaker System (Satellite) Magnetically-Shielded
Power Output (Satellite) 15W + 15W
Power Output (Subwoofer) 30W
Speaker (Diameter) Satellite: 60mm, Subwoofer: 160mm
Speaker Impedance Satellite: 8ohms, Subwoofer: 3.6ohms
Amplifier Input Impedance 6 kohms (at 1 kHz)
Input Stereo mini jack x 1, RCA jack x 1
Output Stereo mini jack × 1
Power Source DC 18V (supplied AC power adaptor)
Dimensions (W x H x D) (Satellite Speakers) Approx. 109 x 212 x 140 mm
Dimensions (W x H x D) (Subwoofer) Approx. 240 x 310 x 318 mm
Weight Satellite Speakers: Approx. 650g (Left), Approx. 600g (Right), Subwoofer: Approx. 4,000g
Price - 89.9€
Note: It has a feature that auto turns on or off the system.
Philips CSS2123/05
Low-rise profile for the perfect fit in front of your TV
Ultra-compact soundbar—just 70 cm/28" wide
Virtual Surround Sound for a realistic movie experience
Dolby Digital for ultimate movie experience
DoubleBASS technology for fuller and deeper bass
Separate subwoofer adds a thrill to the action
Front/Side connections Music iLINK
Rear Connections AUX IN 1, Digital coaxial in, Digital optical in, Subwoofer out
Sound Enhancement DoubleBass, FullSound, Night Mode, Treble and Bass Control
Sound System Dolby Digital
Accessories:
Compatible accessories: Screw x 2, Wall plug x 2
Included accessories: 1 x CR2025 Battery, Power cord, Quick start guide, Remote Control, Safety and Legal Leaflet, Trademarks Sheet, World Wide Warranty leaflet
Connectivity:
Front/Side connections: Music iLINK
Rear Connections: AUX IN 1, Digital coaxial in, Digital optical in, Subwoofer out
Dimensions:
Main Unit (W x H x D): 708 x 47 x 65 mm
Main Unit Weight: 1.03 kg
Subwoofer (W x H x D): 165 x 295 x 240 mm
Subwoofer Weight: 2.6 kg
Subwoofer cable length: 3.3 m
Packaging (W x H x D): 756 x 395 x 220 mm
Weight incl. Packaging: 5.4 kg
Loudspeakers:
Loudspeaker types: Integrated with main unit
Speaker Drivers per side: 1 x 5" woofer, 1 x 1.5" Mylar tweeter
Speaker Impedance: 4 ohm
Subwoofer type: Passive
Subwoofer driver: 1 x 6.5" woofer
Subwoofer freq range: 20–150 Hz
Subwoofer impedance: 8 ohm
Power:
Power consumption: 20 W
Power supply: 220-240 V, 50 Hz
Standby power consumption: < 0.5 W
Sound:
Sound Enhancement: DoubleBass, FullSound, Night Mode, Treble and Bass Control
Sound System: Dolby Digital
Speaker output power: 15 W x 2
Subwoofer output power: 30 W
Total Power RMS @ 30% THD: 60 W
Price:100€
_________________________
What's the pros and cons of these systems? I play a lot of movies (laptop with xbmc - hdmi) and games (Playstation 3 - hdmi)
Please help me to decide what's best for me.
rbmaster is offline
post #2 of 8 Old 11-30-2012, 02:15 PM - Thread Starter
rbmaster's Avatar
rbmaster is offline
post #3 of 8 Old 12-01-2012, 09:54 AM - Thread Starter
rbmaster's Avatar
rbmaster is offline
post #4 of 8 Old 12-01-2012, 05:36 PM - Thread Starter
rbmaster's Avatar
rbmaster is offline
post #5 of 8 Old 12-03-2012, 08:36 AM - Thread Starter
rbmaster's Avatar
So I ordered the Sony D8, I'll have it by friday since they had no stock of it.... Did I choose well?
C'mon people, I know that low budget audio doesn't interest you much but I'm clearly a newbie needing help from you :-/
rbmaster is offline
post #6 of 8 Old 12-04-2012, 07:59 AM - Thread Starter
rbmaster's Avatar
rbmaster is offline
post #7 of 8 Old 12-04-2012, 09:06 AM
UGAd13's Avatar
Quoted: 100 Post(s)
Liked: 121
You won't get many responses for this type of system and since you bought one already I don't think any of the 'pros' will reply. If you like it then use it. If not, then return it. Just don't expect great sound from either but it'll be an improvement over the TV speakers.
My living room budget build: Samsung PN51E530 / Denon AVR1613 / DefTech PC1000 / DefTech PM60 / DefTech ProSub 60 / Dayton Sub1200
UGAd13 is offline
post #8 of 8 Old 12-04-2012, 09:30 AM - Thread Starter
rbmaster's Avatar
Thanks for taking the time to answer.
These are two very distinctive systems, one is 2.1 with SRS sound, the other is a soundbar with separate sub-woofer that supports dolby digital and has many sound enhancement capabilities, and I was asking what's best for cinema and gaming, and the pros and cons of both systems.
Previously I had an old but very good floor-stand sony speakers with integrated amplifier and two integrated subwoofers, worth almost 1500£ when it was brought back in year 1999, but I don't have the proper space in this bedroom anymore because the tv and the furniture is much bigger now. The integrated speakers of this TV are awful, I'm using the 20£ logitech 2.1 ls21 until the new speaker system arrives and I can tell you even those 20£ speakers are a big improvement over the tv speakers.
rbmaster is offline
Reply Speakers
