I'm confused - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-30-2012, 01:44 PM - Thread Starter
DADEO's Avatar
I have a pair of BP-8b's and I have avaliable to me a pair of Studio Monitor 450's. What problems am I going to run into if I try to use these together? Any advantage/disadvantage using either one as fronts or rears? Thank you.
DADEO is offline
post #2 of 2 Old 11-30-2012, 01:49 PM
jevans64's Avatar
Quoted: 189 Post(s)
Liked: 145
BP8b as front and the SM450 in back. I don't see any major problems other than the smaller mids in the BP8b. BP8b have two mids so there will probably be little if any impact overall. Same "type" of speaker design, so probably a better match than using the newer stuff.
Denon AVR X7200WA, Emotiva XPR-5, Emotiva XPA-7, Sony XBR 75" 850C, Oppo UDP-203, Roku Ultra.
DefTech BP7000SC (L/R), CLR3000 (C), SM55 (FH), UIW BPZ/A (SB), UIW 75 (TM).
JBL L7 (Sur), EoSone RSR 350 (RH).
PC 2.1 setup. Emotiva Stealth 6, SVS SB16-Ultra sub, Emotiva DC-1 DAC.
jevans64 is offline
Reply Speakers
