Definitive Technology pro600 newbie questions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-01-2012, 07:30 PM - Thread Starter
jasonpham's Avatar
Hi all,
Really need your help here.
My bedroom size is 12' x 14'.
I recently picked up the Definitive Technology ProCinema Series 600 for about 2 months now.
I am using Denon 2113CI
I am a newbie about speakers and do not know much about how to get the best sound out of it like at Best Buy.
Can you recommend to me the best settings (loudness, bass adjustments, speakers frequency, etc)?
If you can be specific on how you set it up to get the best sound out of it. I'd really appreciate it.
Thanks so much.
I am thinking about switching it to Definitive Technology ProCinema Series 800 for this bedroom size, should i or should i not?
jasonpham is offline
post #2 of 5 Old 12-01-2012, 08:30 PM
Knucklehead90's Avatar
Quoted: 495 Post(s)
Liked: 423
First off are all of your speakers at ear level? This is important. Also subwoofer location is important. You can't stick it hard into a corner - it has to breath. If it has a port on the back it should be at least 2' from a corner more or less.
Check out this link for proper room setup - and if you haven't run Audyssey on the Denon - do so - right after you get all the speakers and sub in the right places.
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 amps - Salk Song Towers - Oppo 103
Vinyl Room: Emotiva PT-100 - ST-120 amp - Acoustic Research AR-2ax - Marantz TT42 - Oppo 103
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is online now
post #3 of 5 Old 12-01-2012, 11:23 PM
jevans64's Avatar
Quoted: 194 Post(s)
Liked: 149
The Dolby guide in the link above is what I'd go with but there is some wiggle room as far as placement on an equal plane with your ears since those ProMonitor satellite speakers are usually mounted on a wall with the articulating mounts. Running Audyssey and using a few mic locations will improve sound quality quite a bit even though they might not be set up exactly to Dolby/THX specifications. You can only set them up as best you can in the room they are in.
I wouldn't consider Best Buy as a gauge on how to set them up. Best Buy usually just throws the stuff on a wall or shelf with little or no regard as to what the best setup would be. I doubt they even did any room correction.
Denon AVR X7200WA, Emotiva XPR-5, Emotiva XPA-7, Sony XBR 75" 850C, Oppo UDP-203, Roku Ultra.
DefTech BP7000SC (L/R), CLR3000 (C), SM55 (FH), UIW BPZ/A (SB), UIW 75 (TM).
JBL L7 (Sur), EoSone RSR 350 (RH).
PC 2.1 setup. Emotiva Stealth 6, SVS SB16-Ultra sub, Emotiva DC-1 DAC.
jevans64 is offline
post #4 of 5 Old 12-02-2012, 12:05 AM - Thread Starter
jasonpham's Avatar
Hi Jevan,
They are at ear level and perfectly placed in the room. The shape of my room is rectangular without any cutting corners.
I am still not getting the best sound that I am pleased with. If you have this system. Can you let me know what your settings are?
post #5 of 5 Old 12-03-2012, 07:15 AM
zibanez's Avatar
Quoted: 36 Post(s)
Pro Cinema 600 has recommended connection, have you try it?
I.ve got pro cinema 600 and using method 1 for speaker connection. So far I'm very pleased with the sound
Bedroom theater
Dynaudio DM 2/6 - Dynaudio DM Center - Def tech pro monitor 600 - Rythmik Audio CI 15" HP600 - Marantz NR1402 - Bantam Gold Power Amp - Clark Synthesis tst 239 - Dune H1 - PS3
zibanez is offline
Reply Speakers
