Looking for a good 5.1 Home Theater Setup - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 52 Old 01-18-2013, 11:09 AM
crussader's Avatar
Quoted: 49 Post(s)
Liked: 29
Originally Posted by xtreme23 View Post
banana plugs are the best and insure the best quality?
Actually, the best quality connection comes from attaching the bare wire directly to the binding post.
Banana plugs are used for convenience for those who frequently plug and unplug their speaker wires, or for cosmetic reasons.
David
crussader is offline
post #32 of 52 Old 01-18-2013, 11:13 AM
crussader's Avatar
Quoted: 49 Post(s)
Liked: 29
btw were did u get the flextech sleeve cover. cant find it anywhere
Google "furryletters"
And check out this thread:
http://www.avsforum.com/t/1301573/have-a-look-at-these-beauties-how-to-make-your-own-high-end-cables
David
post #33 of 52 Old 01-18-2013, 11:16 AM - Thread Starter
xtreme23's Avatar
xtreme23 is offline
post #34 of 52 Old 01-18-2013, 11:23 AM - Thread Starter
xtreme23's Avatar
xtreme23 is offline
post #35 of 52 Old 01-18-2013, 12:01 PM
GusGus748s's Avatar
Quoted: 428 Post(s)
Liked: 705
Ebay,
I recommend the 3/8". I used the 1/2", and it is as snug. FlexTech is about $10 dollars for 25 FT. I bought a different brand, which cost me $24 dollars shipped for 100FT roll, and it is the same quality as FlexTech.
This is what I got:
http://www.ebay.com/itm/350675902106?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Or Flextech stuff
http://www.ebay.com/itm/3-8-BRAIDED-EXPANDABLE-SLEEVING-carbon-TECHFLEX-25ft-/360362483379?pt=Car_Audio_Video&hash=item53e7471eb3&vxp=mtr
GusGus748s is offline
post #36 of 52 Old 01-18-2013, 08:03 PM
colohtpc's Avatar
you are doing great. IMO skip the banana plugs as i tried to state earlier bare wire connections to binding posts are really better (less points of failure) unless you plan on making allot of moves or just want to save one bit of pain on the back of your AVR.
colohtpc is offline
post #37 of 52 Old 01-18-2013, 10:04 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4783
I think my first receiver had just cap screw terminals wink.gif I used bare wire for a long long time without bananas. I just started making a few changes here and there, had a receiver die and had to switch things around, etc so bananas made sense only then for me. But.....if you're going to go bananas ( cool.gif ) ....
lovinthehd is offline
post #38 of 52 Old 01-19-2013, 05:22 AM
skidog's Avatar
Liked: 27
Panasonic TC-P65VT50
Denon 2113ci
Panasonic DMP-BDT220P
Ascend CMT-340SE L/R
Ascend CMT-340SE Center
Ascend CBM-170SE Surrounds
Klipsch RW12-D x 2
skidog is offline
post #39 of 52 Old 01-24-2013, 04:52 PM - Thread Starter
xtreme23's Avatar
hey guys,
thanks so much for all ur help. Got things setup a cpl days and am loving it ever since. and HOLY **** the subwoofer is big. insane but it really bangs hard. speakers are awesome and love the brand. might get the same brand for my car. either ways thanks for everything. and i did go the banana plug. GLS audio tips/banana. Will take a picture once I wire everything up with the flextech.
Thanks again for all the help
xtreme23 is offline
post #40 of 52 Old 01-24-2013, 05:11 PM
pioneertop's Avatar
Quoted: 28 Post(s)
Liked: 176
hey guys,
nice..enjoy. all of the H.T. goodness.. let's see some picts
loves...home theather/music/football:)
pioneertop is offline
post #41 of 52 Old 01-26-2013, 07:55 PM - Thread Starter
xtreme23's Avatar
Hey guys another question I have is that i bought 16 gauge wire sleeve's but it doesn't seem fit my 16 gauge from monoprice? Any idea what I shud do? I can't find bigger gauge sleeves
http://www.knukonceptz.com/productdetail.cfm?prodid=SP16
xtreme23 is offline
post #42 of 52 Old 01-27-2013, 10:04 AM - Thread Starter
xtreme23's Avatar
Sry I meant wire pants
xtreme23 is offline
post #43 of 52 Old 01-27-2013, 11:50 AM - Thread Starter
xtreme23's Avatar
sorry for the mess, gotta clean my room again :/ but heres some pics. love this setup, thanks again for all the advice
xtreme23 is offline
post #44 of 52 Old 01-28-2013, 09:36 PM - Thread Starter
xtreme23's Avatar
what do u guys think? sound is pretty amazing and lovin the bass
xtreme23 is offline
post #45 of 52 Old 01-28-2013, 10:00 PM
jevans64's Avatar
Quoted: 208 Post(s)
Liked: 162
Well. According to the specs., those pants are about 7.36 mm ( 0.29" ) ID at the sheath end. Best way to make sure is to use a caliper to measure the cable with TechFlex installed and then order the closest pants you can find at Parts Express. I think 8mm still might be too small unless you want a really tight fit, so maybe the 9mm pants. Looks like they are $5.50 for 10 at Parts Express. A semi-cheap caliper will cost about $20 at Harbor Freight Tools and I used one to dial in the 0.29" SAE and switch to metric for 7.36mm. LOL
As far as those speakers. Get them up to ear level and... clean your room. tongue.gif
Denon AVR X7200WA, Emotiva XPR-5, Emotiva XPA-7, Sony XBR 75" 850C, Oppo UDP-203, Roku Ultra.
DefTech BP7000SC (L/R), CLR3000 (C), SM55 (FH), UIW BPZ/A (SB), UIW 75 (TM).
JBL L7 (Sur), EoSone RSR 350 (RH).
PC 2.1 setup. Emotiva Stealth 6, SVS SB16-Ultra sub, Emotiva DC-1 DAC.
jevans64 is offline
post #46 of 52 Old 01-29-2013, 12:40 PM - Thread Starter
xtreme23's Avatar
thanks for the help. i ended up with 11mm just to be sure. but yea i cant get them ear level cuz theres no room up there
xtreme23 is offline
post #47 of 52 Old 01-29-2013, 03:26 PM
jevans64's Avatar
Quoted: 208 Post(s)
Liked: 162
FYI. I used their 11mm pants for 10 gauge wire wrapped in TechFlex. The fit was a little tight for 10 gauge but 12mm pants wasn't an option.
jevans64 is offline
post #48 of 52 Old 01-29-2013, 06:34 PM - Thread Starter
xtreme23's Avatar
i found 14mm as well.
http://www.parts-express.com/pe/showdetl.cfm?partnumber=082-784
xtreme23 is offline
post #49 of 52 Old 01-29-2013, 07:25 PM
GusGus748s's Avatar
Quoted: 428 Post(s)
Liked: 705
I like the KnuKonceptz speaker wire pants of the Parts Express ones. The PE speaker wire pants are too short. The KnuKonceptz you can cut them to the desire lengths.
post #50 of 52 Old 01-29-2013, 10:25 PM - Thread Starter
xtreme23's Avatar
yea true. but are limited in size. bought 16 gauge and they wouldnt fit my wires
xtreme23 is offline
post #51 of 52 Old 01-29-2013, 10:36 PM
GusGus748s's Avatar
Quoted: 428 Post(s)
Liked: 705
I've only done 12 gauge CL2 monoprice wire, and the 12 gauge KnuKonceptz worked fine. They wouldn't go over the speaker wire sleeve, but it was find since I used shrink wrap to hold it in place.
post #52 of 52 Old 02-09-2013, 12:57 PM - Thread Starter
xtreme23's Avatar
lovin this setup. got techflex all setup. had to 3/4" route but still does look good. will post pictures later. thanks to everyone that helped out
xtreme23 is offline
Reply Speakers
