Any Advice for New Speaker Setup? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 12-03-2012, 08:46 PM - Thread Starter
cdudek's Avatar
Hey Everyone,
I am building a home theater for my living room. My setup is:
Receiver: Pioneer VSX-42
TV: Sony KDL NX810
Speakers: Polk Audio RM 75
Subwoofer: Polk Audio PSW505
Components: AppleTV, PS3
Just wanted to hear some experts opinions. I don't have space for floor standing speakers. Is this a pretty good setup? Right now I have a smaller sized living room but plan to be moving soon. Will it be good for a larger room?
Going to set it all up tomorrow, wish me luck!
Thanks in advance.
-Chris
cdudek is offline
post #2 of 9 Old 12-03-2012, 08:58 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Those speakers wont cut it for a large room. The sub isnt great, but its more cut out for a larger room then tiny satellite speakers.
Jay1 is offline
post #3 of 9 Old 12-03-2012, 09:09 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Thanks in advance.
-Chris
Not easy to wish you luck with those small Polks - hope that they
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #4 of 9 Old 12-03-2012, 09:16 PM - Thread Starter
cdudek's Avatar
What speakers would you suggest for around $300? Are there better ones I could get for that price range or should I just sit on these until I can spend more money?
cdudek is offline
post #5 of 9 Old 12-03-2012, 09:21 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
HTD Level Two and center
http://www.htd.com/Products/level-two-speakers
There is some B-stock here
http://www.htd.com/Products/B-Stock
Who AM I
zieglj01 is offline
post #6 of 9 Old 12-04-2012, 06:39 AM - Thread Starter
cdudek's Avatar
Thanks for the feedback/advice. It's definitely appreciated. These ones look nice. I'm going to keep my eye on them.
cdudek is offline
post #7 of 9 Old 12-04-2012, 07:26 AM - Thread Starter
cdudek's Avatar
For speaker wire, I've heard mixed reviews. I purchased just pretty standard stuff a long time ago (AUD-5610-99 --> Cables Unlimited Pro A/V Speaker Wire). Thinking of upgrading to Monster speaker wire. Is it worth it?
Sorry for all the questions but I just want to make sure I don't f myself with bad wires.
cdudek is offline
post #8 of 9 Old 12-04-2012, 07:42 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
The Wharfedale Diamond 10.1 speakers are excellent. Music Direct sells them for $349 per pair. The front speakers need to be larger than what you have; the PSW505 is not too bad.
If that is outside your budget, another good small pair is the Cambridge Audio S30, which are $219.
Either of those speakers will be a HUGE upgrade over the front speakers you have.
For speaker wires, get some #14 speaker wire from Monoprice; product #2748 for $13.
Everything Monster makes is pretty poor in my experience; that's one brand I never recommend.
commsysman is offline
post #9 of 9 Old 12-04-2012, 08:05 AM - Thread Starter
cdudek's Avatar
Thanks for the advice. I just bought some of the monoprice 14 gauge. Too bad I have to wait for it to ship now, but it'll be worth it. Going to keep digging into different speakers while I wait. I appreciate all of the advice.
cdudek is offline
Reply Speakers
