Def. Tech Studio Monitor 65's with a CS-8080 center - AVS Forum | Home Theater Discussions And Reviews
Old 12-04-2012, 01:48 AM - Thread Starter
TenTonBass's Avatar
Quoted: 16 Post(s)
When I upgrade my frontstage I have already decided I am going monitors for mains as %95 of my source is movies.
Ideally I know just buying a 3rd monitor 65 for the center would be the best match, but I would like the center to have a little more oomph.
Do you think this setup would be ok or no as far as timbre matching and all?
TenTonBass is offline
Old 12-04-2012, 07:13 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
That setup would work just fine as all of the newer Definitive Technology are voiced the same, in order for them to all work together. The third SM-65 would likely have more oomph than the CS-8080 due to the SM-65 having larger drivers. That would be the best way to go. No matter which speaker brand you go with, having a 3rd matching speaker to the Lefts and Rights is always the best and most preferable way to do it as the horizontal placed center channels are always a design compromise only made that way in order to be more space effecient.
Martycool007 is offline
Old 12-04-2012, 11:59 AM - Thread Starter
TenTonBass's Avatar
Quoted: 16 Post(s)
They both have 5 1/4" midrange drivers but he CS-8080 has a built in powered subwoofer.
Old 12-04-2012, 12:53 PM
joeatdefinitive's Avatar
Hello Ten, personally I would suggest a CS-8080 center, if you can swing it. The powered sub in the middle can really help with dialog and effects realism. The SM 65 is also a fine choice if you can't gather up the bucks for the CS-8080, but as you say that your main usage is movies, you really want the dialog to be as realistic as possible. No worries about timbre-matching issues from our perspective. I hope this helps - best, Joe
joeatdefinitive is offline
Old 12-04-2012, 01:06 PM - Thread Starter
TenTonBass's Avatar
Quoted: 16 Post(s)
Old 12-04-2012, 02:17 PM
Elihawk's Avatar
Quoted: 1015 Post(s)
Liked: 860
You can get the sm350/450 for around 200 dollars/ pr from New Egg!
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is offline
