Upgrade 1995 KLH 900 b three way speaker system - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-04-2012, 01:09 PM - Thread Starter
Teletodd's Avatar
I have the above speakers as the fronts, a 2 way KLH center and small square KLH surrounds. I recently upgraded my reciever to a Denon 1713 and added a 12 inch powerd sub woofer. Sounds great but Im now researching upgrading the fronts and center, and re-using the old KLH 3 way fronts as the surrounds. I found a few old positive reviews on the 900b on the web and theyre in great shape..
I looked at Klipsch Icon K15 fronts and a matching center at my local BestBuy for around $500.00. The salesman tauted the tweeters and said that alot of movie theaters use Klipsch. I surmise that they would be a significant upgrade to my KLH system, however not sure if i have to spend that much, or if theyre the best bang for the buck. Also, not sure if theyd be big enough for my room which is 15' x 25'. Perhaps klipsch RB 51 would handle the room size better, but theyre more than i planned to spend. Starting to look at other brands, but is starting to get overwhelming. Any suggestions?
Teletodd is offline
post #2 of 5 Old 12-04-2012, 02:03 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Look at the HTD Level Three bookshelves and center,
They will beat-up the KLH speakers.
http://www.htd.com/Products/level-three-speakers/Level-THREE-Bookshelf-Speakers
http://www.htd.com/Products/level-three-speakers/Level-THREE-Center-Channel-Speaker
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is online now
post #3 of 5 Old 12-04-2012, 04:10 PM - Thread Starter
Teletodd's Avatar
How do those compare to KB15s?
Teletodd is offline
post #4 of 5 Old 12-04-2012, 04:16 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
For me, the HTD Level Three is clearly a better speaker.
Who AM I
post #5 of 5 Old 12-09-2012, 03:42 PM - Thread Starter
Teletodd's Avatar
Listened to pioneer f22 towers today, my klh 900b speakers sound better. Maybe it's the 8" woofer? Decided to keep them as fronts, might still replace the 2 way klh center someday. I've read here about the perils of mismatched centers, but I have a denon 1713 with audyssey which I've read balances mismatched centers.
Teletodd is offline
Reply Speakers
