Adding Wireless Speakers to Existing 5.1 Hardwired System - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-05-2012, 07:27 AM - Thread Starter
GlassJoe's Avatar
Hey, everyone. I currently have a 5.1 surround system with in-wall speakers in my media room. I am wanting to expand my 5.1 setup to 7.1 utlizing wireless speaker for the rear channels. I would go the in-wall route but I do not have access to the insides of the walls to run the speaker wire therefore that is not an option for me. My question to the forum is whether or not it is possible to add some quality wireless speakers to my current configuration and it sound good. I have a Yamaha 7.1 reciever with speaker wire outputs for the additional two channels available.
If there is not a quality solution to make this work, what would be some other options to gain that coveted 7.1 sound? Thanks in advance!
GlassJoe is offline
post #2 of 3 Old 12-05-2012, 11:03 AM
Bill Fitzmaurice's Avatar
Liked: 4989
Yes, but wireless speakers aren't totally wireless, they simply trade a speaker cable for a power cable. That may be fine if you have AC outlets where you want to place them, otherwise not so much.
Bill Fitzmaurice is offline
post #3 of 3 Old 12-06-2012, 05:45 AM - Thread Starter
GlassJoe's Avatar
Yea, I guess I didn't consider that. Thanks, Bill!
GlassJoe is offline
Reply Speakers
