Do these bookshelf speakers exist? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 12-06-2012, 10:35 AM - Thread Starter
richard11's Avatar
Hi all,
Looking for a short list of bookshelf speakers to consider.
Bookshelf size (doesn't have to be that small, but no towers or almost-towers)
-- these will likely be placed on a wide media center, not on stands.
Decent quality looks
-- no plain black vinyl; at least black ash or gloss. Colored wood finishes better. Must have grille.
Bass response -3 dB at 40 Hz in room (or better)
-- my room is open, medium size, and placement is few feet from wall.
At least 89 dB 1w/1m efficiency
-- listening position is about 10 ft. away
Budget: $800 - $1500 / pair (somewhat flexible)
On my list right now:
Ascend Sierra-1 (opt. NrT)
Soundfield Monitor 1 (A/C power is not an issue)
They are both listed at 86.5 dB, but meet the other criteria.
Thanks for the input!
richard11 is offline
post #2 of 7 Old 12-06-2012, 11:14 AM
callas01's Avatar
Quoted: 956 Post(s)
Liked: 584
Dynaudio Excite X16s
Totem Rainmakers
Monitor Audio RX2
Dali Ikon2
Dynaudio Focus 260s, Focus 210C, DM 2/6, Hsu VTF3 MK5 HP, Oppo BDP-103, NaimUniti 2, Naim Stageline N, Pro-ject 2xperience Classic, Marantz SR7007, 60" 4K Samsung LED LCD
callas01 is offline
post #3 of 7 Old 12-06-2012, 11:22 AM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 221
Are you not running a sub? I think the soundfield's would be hard to beat if that's the case.
Jay1 is offline
post #4 of 7 Old 12-06-2012, 12:11 PM
65 Electra Glide's Avatar
Quoted: 78 Post(s)
Liked: 50
+1
Also maybe the Atlantic Technology AT-2s could be a viable option.
65 Electra Glide is offline
post #5 of 7 Old 12-06-2012, 12:28 PM
JerryLove's Avatar
Liked: 82
Have not personally listened to but:
http://soundfieldaudio.net/Products.html
Size: 17" H x 10" w x 12.5" d
"FR: 38-20,000 Hz +/- 3db, 100-10,000hz +/- 2db. Typical in room extension to below 30hz."
It's partially active (the bass driver has built in amplification).
It's not a tiny bookshelf by any means, but I don't think it's a quasi-tower either.
JerryLove is offline
post #6 of 7 Old 12-06-2012, 07:17 PM - Thread Starter
richard11's Avatar
Thanks for the input. I'm thinking Soundfield Monitor 1 will be hard to beat if no sub, as everyone says. But now that I'm agreeing with that, I'm reconsidering a small sub in the corner.
Certainly opens things up if I only need down to 80Hz with efficiency.
post #7 of 7 Old 12-06-2012, 09:16 PM
skriefal's Avatar
Quoted: 97 Post(s)
Liked: 79
The Tekton 8.1T either meets or comes close to your 40 hz requirement, and easily meets your efficiency and price requirements (~95dB/w, $650/pr + extra for veneer options). I think (but am not sure) that you can purchase optional grilles.
http://www.tektondesign.com/model81t.html
skriefal is offline
Reply Speakers
