Bookshelf speakers for a computer powered by an HK3490.....? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-06-2012, 01:52 PM - Thread Starter
shanker's Avatar
I have an HK 3490 I'm not using and I'd like to upgrade the M-Audio AV40s I'm using as they dont due low frequency very well(fall off at 80Hz). I'd rather not use a subwoofer due to space and they would also be for near feild use. Most used for gaming and Netflix streaming.
I have a Creative Labs X-Fi Titanium sound card so i can Toslink or RCA to the receiver Since its for stereo use I dont think it would matter much.
I was looking at Definitive TEchnologies ProMonitor 1000 to the Bowers and Wilkins 685Bs. I'm looking for something that sounds flat and can pick up somewhere around the 60 Hz range. I really only have Best Buy around me to demo stuff which is a problem.
$700 would be my absolute max.
Thanks for any help you can give me!
Matt
shanker is offline
post #2 of 4 Old 12-06-2012, 01:57 PM
afrogt's Avatar
Quoted: 1357 Post(s)
Liked: 940
You might not even need to spend that much for bookshelf speakers.
These Def Tech SM450's may do the trick.
http://www.newegg.com/Product/Product.aspx?Item=N82E16882325060
Transmaniacon likes this.
Afro GT
afrogt is offline
post #3 of 4 Old 12-06-2012, 02:13 PM
Transmaniacon's Avatar
Quoted: 1582 Post(s)
Liked: 1381
Those SM450 monitors would be great, I would also recommend the Behringer 2031P, they are very good near field monitors.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
post #4 of 4 Old 12-06-2012, 02:27 PM
dmsdms's Avatar
Liked: 30
I use Hsu HB-1 bookshelves as my desk speakers and have been really impressed with them. They are listed at 60Hz +/- 2dB but, they have good bass well below that. As a comparison, I also have some Focal Chorus 706V bookshelves that are 55Hz +/- 3dB and the Hsu speakers have much, much strong bass.
dmsdms is offline
Reply Speakers
