Have front speakers...what's next? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 12-06-2012, 04:14 PM - Thread Starter
gcoulson's Avatar
Hi folks,
So after a lot of patience and research, I feel like I've come out on top with regards my AV receiver and floorstanding speakers. Managed to get both for the amount I had budgeted for just one of them, so I have some money left over to buy an additional component.
Right now I just have the floorstanding fronts. My question is, if you just had enough money to buy ONE more component, what would it be? Not sure which would be the best use of my current funds.
Assuming they cost the same, should I go for
- center speaker,
- bookshelf rears, or
- subwoofer.
As mentioned in previous posts, this is for a 50/50 music/video usage system. So with the fronts, I have the music covered. Now just looking for the biggest single improvement on the HT side.
gcoulson is offline
post #2 of 19 Old 12-06-2012, 04:27 PM
grasshoppers's Avatar
Quoted: 802 Post(s)
Liked: 506
Assuming they cost the same....subwoofer! But, don't buy a cheap sub,
You will end up changing it when you get into movies.
Anthem MRX-300-Outlaw Audio M2200
Rythmik F12 subs
Paradigm Signature S6,C1,S1
Harman Kardon DMC1000 (music)
Assassin HTPC (movies)
grasshoppers is offline
post #3 of 19 Old 12-06-2012, 04:53 PM - Thread Starter
gcoulson's Avatar
Looking into the subs, wondering whether I need a ported or sealed for combination of music/HT purposes. System will not be played LOUD since neither I nor my wife can tolerate very loud sound...so volume is not important. However, with floorstanders, not sure if I would need a sub for music, so maybe I need to just focus on a sub for HT?
gcoulson is offline
post #4 of 19 Old 12-06-2012, 11:34 PM
neuspeed94's Avatar
You and your wife are like me and mine. We never watch movies or listen to music anywhere near reference level. And we actually just added another component to the 2 front tower speaker only setup we had. We found a subwoofer that matched our towers on craigslist and now I can officially say, if you are going to add one component, add a subwoofer. The bass that our towers put out was already great (frequency response down to 47Hz) but now that we get to hear frequencies down to 27Hz, it just made our movie watching that much better. Even at the lower to medium volumes that we watch movies and tv at, it's a noticeable difference. Our subwoofer is in a ported enclosure (port is on the bottom of the enclosure) and it has a nice rumble during movies and also sounds good for music. Since you won't be listening to music with the volume cranked up really high, I doubt you would experience any port noise, etc. that is a byproduct of some ported subwoofer enclosures. So I say get a ported one unless you come across a heck of a deal on a sealed subwoofer.
Like grasshoppers said though, don't go the super cheap route and get something like a HTIB plastic subwoofer. What kind of tower speakers do you have? I ask this, because I wouldn't get a subwoofer that was inferior (performance-wise) to my main speakers. You will notice if one component isn't nearly as good as the rest.
neuspeed94 is offline
post #5 of 19 Old 12-07-2012, 06:12 AM - Thread Starter
gcoulson's Avatar
I have a pair of Monitor Audio BR5 speakers which dig down to 35Hz or so according to the specs. I wouldn't get a HTIB sub, but was looking at either HSU STF-1 or -2. Don't need huge output and my room is only 12' x 17'
gcoulson is offline
post #6 of 19 Old 12-07-2012, 06:46 AM
rick240's Avatar
Quoted: 18 Post(s)
Liked: 52
The typical, and likely best, HT build process is:
- 0.0, starting
- 2.0, you're here
- 2.1, get a sub; but like grasshoppers said, don't cheap out, save for longer if you have to; even if you don't listen loud, make sure it can extend to 20Hz for the full HT experience
- 3.1, get a centre; make sure it timbre matches your mains, ideally the same speaker if you can fit it in your space
- 5.1, get rears; don't need to timbre match unless you listen to a lot of muti-channel music
rick240 is offline
post #7 of 19 Old 12-07-2012, 07:13 AM
bjaurelio's Avatar
I say go for the Hsu stf-2. One of my friends has a Hsu sub, and it kicks out low, tight bass. Most on here would agree that Hsu subs are good, especially for the price.
I would have bought the stf-2 if I had the money in my budget, but I ended up with a Polk psw505 for a good deal on Amazon (now even cheaper at $189). I bought bookshelf speakers, so a sub was mandatory for me when I started on my ht. Now I'm getting a center.
I agree with the above progression: mains, sub, center, rears.
bjaurelio is offline
post #8 of 19 Old 12-07-2012, 08:31 AM
neuspeed94's Avatar
Go with the STF-2 over the STF-1 for sure. Only a $30 difference to go from an 8" to a 10" driver and from 32hz down to 25hz. The Hsu STF-2 is what I was going to eventually spring for if I hadn't found the sub I picked up on craigslist for a steal.
post #9 of 19 Old 12-07-2012, 09:25 AM
crussader's Avatar
Quoted: 49 Post(s)
Liked: 29
If your mains were bookshelf speakers, I would agree that you should go with a sub.
With floorstanders I don't think the choice is so clear. If you are getting good bass already, the sub represents a marginal improvemnent (Unless of course you want to feel the bass rather than just hear it).
I would get the center. That changes the whole decoding scheme and makes it more theater like rather than just extending the low frequencies.
Also, right now you can definitely get a center that matches your mains. How long will it be before you add another piece? If it will be a couple of years down the road, a matching center might be harder to find.
David
crussader is offline
post #10 of 19 Old 12-12-2012, 10:04 PM - Thread Starter
gcoulson's Avatar
Hi all, thanks for the great responses. I have a question regarding the sub, with the STF-2 the bass extension is listed as 25 Hz, +/- 2 dB. Is this really all that big a difference from the 35 Hz that my BR5s are pushing out? I'm new to HT, so not sure if 10 Hz actually makes a difference and would be tangible enough to warrant their purchase?
Crussader...I'm keeping an eye out for the matching center, but since they're no longer made, I'm reliant on the second-hand market. Nothing yet.
gcoulson is offline
post #11 of 19 Old 12-12-2012, 10:55 PM
rick240's Avatar
Quoted: 18 Post(s)
Liked: 52
rick240 is offline
post #12 of 19 Old 12-12-2012, 11:37 PM
callas01's Avatar
Quoted: 829 Post(s)
Liked: 461
Ive heard the BX5s and the bass is ok, but a subs bass would be an improvement for the lower frequencies. I would say that the BR5s like the BX5s probably arent playing the lower frequencies very well so augmenting them with a capable sub would be the best path. I would go 2.1, and then when the time comes, I would highly consider surrounds next and a center channel after that. I used to run a 4.1 setup, and the stereo imaging was just as good with movies as with music, but with the benefit of surround sound for movies or blu-ray concerts.
Just a different suggestion.
Dynaudio Focus 260s, Focus 210C, DM 2/6, Hsu VTF3 MK5 HP, Oppo BDP-103, NaimUniti 2, Naim Stageline N, Pro-ject 2xperience Classic, Marantz SR7007, 60" 4K Samsung LED LCD
callas01 is offline
post #13 of 19 Old 12-13-2012, 06:45 AM
Nuance's Avatar
Quoted: 21 Post(s)
Liked: 77
Any chance you can step up to a Rythmik FV12?
http://rythmikaudio.com/FV12.html
My journey to find the "perfect" speaker
No matter what measurements tell us, a loudspeaker isn’t good until it
sounds good. - Dr. Floyd Toole
Nuance is offline
post #14 of 19 Old 12-13-2012, 08:09 AM - Thread Starter
gcoulson's Avatar
No, at $550, its way out of budget.
gcoulson is offline
post #15 of 19 Old 12-13-2012, 08:12 AM
Nuance's Avatar
Quoted: 21 Post(s)
Liked: 77
Gotcha. Sorry, I didn't see a listed budget so I figured I'd throw it out there. smile.gif
Nuance is offline
post #16 of 19 Old 12-13-2012, 09:35 AM
neuspeed94's Avatar
Originally Posted by rick240 View Post
Agreed. You will definitely notice the difference and all of the frequencies you were missing while not having a sub. Besides, having the sub will do more than just play the 10hz between 35 and 25. You will set your crossover in your receiver to around 80hz and let the sub handle the duties from 80hz on down because it is better suited for strongly producing those frquencies than your towers. Then your towers can really focus on 81hz and up.
post #17 of 19 Old 12-13-2012, 11:12 AM - Thread Starter
gcoulson's Avatar
Certainly makes sense, thanks. In this case I imagine I would have to set my speakers too small? If that is true was there any value in getting floorstanders in the first place since I'm not using anything below 80 Hz?
gcoulson is offline
post #18 of 19 Old 12-13-2012, 11:32 AM
Nuance's Avatar
Quoted: 21 Post(s)
Liked: 77
Correct - set them to small. There are many reasons to go with towers, such as they fill a large room better, there can be less of a phase issue at the crossover region and they allow you to crossover lower then 80Hz if you'd like (depends on the speaker, of course). Sub(s) and a pair of monitor-style speakers would work well too.
Nuance is offline
post #19 of 19 Old 12-14-2012, 09:35 AM
neuspeed94's Avatar
After I got my sub, I tested my setup with the towers set to small on the receiver and the towers set to large. I prefer the way it sounds with the towers set to large. The midbass on the towers is just too good to give up any of it. My crossover is set to 80hz.
Reply Speakers
