Newb Question about Airport Express Hookup - AVS Forum | Home Theater Discussions And Reviews
Old 12-08-2012, 03:44 PM - Thread Starter
hogpen's Avatar
I have absolutely no experience with speakers and have a question about hooking up an Apple airport express to my current speakers. I haven't bought the airport express yet but on the picture from Apple's site it shows an input for "analog/optical audio jack" that I would plug into a set of speakers. I have a decent set of speakers that I'd like to use instead of buying new ones but I'm not sure if they're too old.
Below is a picture of the back of one of my speakers:
http://i47.tinypic.com/i1ivix.jpg
Would those connect to the Apple device or is there a converter I could buy?
Any help would be greatly appreciated! Thanks in advance.
hogpen is offline
Old 12-08-2012, 04:15 PM
nmerriam's Avatar
The Airport Express has an optical/analog 3.5mm audio out jack, similar to a headphone jack on an iPod. you can't plug it directly into standalone speakers like you have. You either need to put the audio from the Express into an amplifier, and the amplifier drives your current speakers, or get a set of powered speakers (where they can take that low level of sound and amplify it themselves). There are a number of small, cheap amplifiers that could work, a well-regarded one is the Lepai LP-2020A+. It depends how much power you need, how big the space is, etc. If this is just for listening to music in your office, that setup would be fine, but if you're trying to watch movies in the living room, it will probably be woefully underpowered.
nmerriam is offline
Old 12-08-2012, 06:09 PM - Thread Starter
hogpen's Avatar
Great, thank you nmerriam!
hogpen is offline
