Minimalistic stereo speakers with integrated amplifier? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 12-08-2012, 09:31 PM - Thread Starter
DominicoBalogini's Avatar
I'm no audiophile and I only watch movies and play games on low volume -- but I can't stand the integrated TV speakers.
Anyone can recommend a super minimalistic stereo speakers (no sub or some kind of internal subwoofer implementation), preferably wooden, with integrated amplifier? I don't want a separate amplifier device either.
DominicoBalogini is offline
post #2 of 13 Old 12-08-2012, 09:35 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Budget? Does your TV have RCA audio outs, or are they only optical, or are you able to use your cable box?
Jay1 is offline
post #3 of 13 Old 12-08-2012, 09:53 PM - Thread Starter
About $200.
Actually I don't even need an amplifier, I guess.
I would like to use a setup like this:
TV ---> Sonos Connect ---> active stereo speakers
I have a Panasonic ST50, it has RCA outs and optical out too. How would you recommend to set this up?
post #4 of 13 Old 12-08-2012, 10:15 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Something like these speakers
http://www.amazon.com/gp/aw/d/B000EJTXZU/ref=mp_s_a_1?qid=1355029589&sr=1-24&pi=SL75
Then you need two of these cables, one for each L/R or the RCA out like in the picture posted. If you use your tv's outs you can get sound for everything running though your tv, which is preferred when you aren't using a receiver.
http://www.amazon.com/gp/aw/d/B0026K8X7O/ref=mp_s_a_1?qid=1355029819&sr=1-2&pi=SL75
Jay1 is offline
post #5 of 13 Old 12-08-2012, 10:32 PM - Thread Starter
I assume they must work with that Sonos device in between, since it's just a bridge.
Also, the ones you posted look quite good, but too bulky for my taste, is there any mainstream-ish slim-type or satellite-type pair which you could recommend? I'm looking for something minimalistic.
post #6 of 13 Old 12-08-2012, 10:54 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
I don't recommend speakers with less then a 5" woofer, even more so if you won't have a sub
Jay1 is offline
post #7 of 13 Old 12-08-2012, 11:06 PM - Thread Starter
That makes sense. I shouldn't go with slim or satellite designs then. What do you think about this set? It's not powered. What's the main difference between those Alesis M1 520 and these Sony's, just so I can understand?
http://www.amazon.com/Sony-SS-B3000-Bookshelf-Speakers-Black/dp/B000OG6I6A/ref=sr_1_25?s=electronics&ie=UTF8&qid=1355032560&sr=1-25&keywords=studio+monitors
EDIT:
Just realized I would need an amp for those.
So what about Numark NPM5? Much more compact:
http://www.amazon.com/Numark-NPM5-Studio-Monitor-System/dp/B0038YX39A/ref=cm_cr_pr_product_top
post #8 of 13 Old 12-08-2012, 11:48 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
The biggest difference is you need an amp to run the Sony's. The Sony's are also very low quality, don't have a real crossover, not recommended.
Jay1 is offline
post #9 of 13 Old 12-09-2012, 12:05 AM - Thread Starter
post #10 of 13 Old 12-09-2012, 12:13 AM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Never heard of them so I can't really say. Good thing about amazon is hassle free returns so you might as well give them a shot.
Jay1 is offline
post #11 of 13 Old 12-09-2012, 12:36 AM - Thread Starter
Thanks so much. Just realized I would need a toslink to RCA adapter since my TV only has optical audio out. Any experience with those adapters?
post #12 of 13 Old 12-09-2012, 12:46 AM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Jay1 is offline
post #13 of 13 Old 12-09-2012, 02:47 PM - Thread Starter
Alternatively, can I use the headphone jack audio out from the TV?
Reply Speakers
