Dent on JBL ES100 low-frequency 10'' speaker - AVS Forum | Home Theater Discussions And Reviews
Old 12-09-2012, 03:48 PM - Thread Starter
rai555's Avatar
Hi, i just bough second hand speakers with the dent, it does not affects sound ( i hope ) but it does not look right. Not sure what could be next step trying to fix it. I can post a picture if that would help. No idea what is the speaker model and google did not helped . Your advise would be greatly appreciated
Thank you in advance
rai555 is offline
Old 12-09-2012, 07:59 PM
MandM's Avatar
Quoted: 79 Post(s)
Liked: 40
CAREFULLY try using your vacuum cleaner to fix this 'dent'.
rai555 likes this.
MandM is offline
Old 12-10-2012, 01:15 PM
jdcrox's Avatar
Quoted: 78 Post(s)
Liked: 102
Sounds like the spherical dust cover over the center of the driver? If so, yes a vacuum can work, also a piece if tape pressed to the dent and pull it out.
rai555 likes this.
jdcrox is offline
Old 12-10-2012, 03:46 PM - Thread Starter
rai555's Avatar
rai555 is offline
Old 12-11-2012, 07:04 AM
Espo77's Avatar
Quoted: 179 Post(s)
Liked: 84
The vac has worked for me. You don't want to use a large overpowering commercial vac...LOL. I used a smaller sized vac. Place the end of the hose directly on the dust cap, then turn the switch on and off in one fast motion. One try usually does it.
Espo77's living room equipment: RECEIVER: Yamaha RX-A3030- SPEAKERS: Boston Acoustics M350, M25 center, surrounds, and front heights-
BLU-RAY: Oppo BDP103D- SUBWOOFER: HSU VTF-15H MK2- dedicated circuits for A/V- TV: Vizio P55C-1
Auralex Acoustics LENRD - Auralex Acoustics Roominator
Espo77 is offline
