Avr-1613 speaker match - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 12-10-2012, 09:47 AM - Thread Starter
lokigee's Avatar
I have just purchased the Denon AVR-1613 and I am now looking to upgrade my speakers. I am by no means an audiophile, but I do want a nice sounding system, with out breaking the budget. Just looking to buy center channel and front speakers for now.
lokigee is offline
post #2 of 16 Old 12-10-2012, 11:02 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
You need to provide way more info.
1. Budget (in US $ preferrably)
2. Size of room
3. Budget
4. Type of speakers (towers, bookshelf, satellites) Any size limitations?
5. Will you eventually get a subwoofer?
6. Main use, (home theater, games, music?)
7. Location (are you in the U.S.)
8. Budget!
As you can tell, can't make any recommendations w/o a budget! smile.gif
Afro GT
afrogt is offline
post #3 of 16 Old 12-10-2012, 11:06 AM
Elihawk's Avatar
Quoted: 1014 Post(s)
Liked: 856
And the model of your AV-R is not relevant...unless you plan to buy very low sensitivity speakers!
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is offline
post #4 of 16 Old 12-10-2012, 11:11 AM
afrogt's Avatar
Liked: 755
Well, I think its always nice to know what receiver you have.
Afro GT
afrogt is offline
post #5 of 16 Old 12-10-2012, 11:59 AM - Thread Starter
lokigee's Avatar
Ok. My budget would be about $300 u.s. room size is about 12 x 20. Im thinking bookshelfs or maybe satellites. I Would eventually buy a sub yes( I have a small crappy one that came in a home theater in a box. That I will use in the mean time). I use the setup for watching tv and movies mostly and a little for gaming. I live in Canada near the us boarder to Washington. So I can order things online and pick them up across the border. Hope this helps
lokigee is offline
post #6 of 16 Old 12-10-2012, 12:37 PM
Elihawk's Avatar
Liked: 856
Okay, yes, it doesn matter- but just becuase of the example I mention- low sensitivity speakers are not a good match for a low powered receiver.
Elihawk is offline
post #8 of 16 Old 12-10-2012, 12:42 PM
afrogt's Avatar
Liked: 755
Not sure if you're willing to drive down to the Seattle area or not but they have the Infinity Primus P153 and P163 speakers on sale.
P153 is $99/pr and uses a 5.25" woofer
P163 is $119/pr and uses a 6.5" woofer
http://www.frys.com/ads/page6
The PC251 or PC351 center can be found on Amazon.
Afro GT
afrogt is offline
post #9 of 16 Old 12-10-2012, 01:46 PM - Thread Starter
lokigee's Avatar
Is there any satellite speaker system that are worth buying?
lokigee is offline
post #10 of 16 Old 12-10-2012, 02:35 PM
LCDeez's Avatar
LCDeez is offline
post #11 of 16 Old 12-11-2012, 09:40 AM - Thread Starter
lokigee's Avatar
Anybody have any input on the klipsch speaker set? Or the energy one? As the small satellite speaker may please the wife more than larger bookshelf type speaker.
lokigee is offline
post #12 of 16 Old 12-11-2012, 11:00 AM
Elihawk's Avatar
Liked: 856
3 inch or smaller driver will lack midbass and volume...so they are designed for very small rooms!
Elihawk is offline
post #13 of 16 Old 12-11-2012, 11:06 AM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
For me maybe one or two, however not in your budget
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #14 of 16 Old 12-11-2012, 11:10 AM - Thread Starter
lokigee's Avatar
What kinda price range would I be looking at? And what models?
lokigee is offline
post #15 of 16 Old 12-11-2012, 11:25 AM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
In general, I prefer bigger speakers - however, if you need to go small
due to wife preference > then look at Acoustic Energy, this package is
on close-out pricing and use to list for around $1700
http://www.accessories4less.com/make-a-store/item/ACENAEGOPACK/ACOUSTIC-ENERGY-AEGO-AE12-5.1-Home-Theater-Speaker-Package-Gloss-Black/1.html
http://www.avreview.co.uk/news/article/mps/uan/1063
Not on close-out pricing, and will cost more >
NHT
http://www.nhthifi.com/bookshelf-speakers-subwoofer-Super-Surround-5-1?sc=12&category=3830
Who AM I
zieglj01 is offline
post #16 of 16 Old 12-11-2012, 01:05 PM - Thread Starter
lokigee's Avatar
Well thank you all for the advice. I think I might go with some Polk audio monitor 40s for font speakers(maybe move them to the back when I can afford it) and the Polk cs2 for a center channel.
Edit: unless you guys suggest something else
lokigee is offline
Reply Speakers
Denon Avr 1613 Receiver
