Best setup? - AVS Forum | Home Theater Discussions And Reviews
Old 12-10-2012, 03:31 PM - Thread Starter
eyelwatch's Avatar
So Ive got a BIC F12 with polk monitor 60s as my L/R, and a pok CS1 for my center. all other satellite speakers are from my previous Onkyo HTIB (HT-R667). I decided to put my old sub behind my sectional sofa. The room is 27X16ft. I ran audyssey while only having the BIC 12 plugged in and it set my sub at -11db and my L/R speakers set to large. Does this seem right. Doesnt seem like very much base. BTW crossover is set to 100Hz on onkyo and all the way up on the sub.
eyelwatch is offline
Old 12-10-2012, 09:21 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
With it at -11 it sounds like you have the gain knob turned up way to high on the sub. Turn the gain down and re-run audyssey. I would also set all speakers to small and the xover at 80hz after audyssey. You can also turn the subs level up a few db until it sounds better to your ears.
Jay1 is offline
Old 12-11-2012, 07:33 AM - Thread Starter
eyelwatch's Avatar
I'll give it a try, thanks for the tips.
