New theater build - 1,000.00 speaker budget. (already have sub) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-10-2012, 02:54 PM - Thread Starter
MBRICHARD's Avatar
Just looking for some final opinions...
My dedicated theater room is arriving completion this week- after some exhaustive research (and help from you guys), I have decided on the HTD Level 2 series towers for my fronts, the center, and surrounds. I have a Klipsch RW-12D on the way from the Newegg sale. Receiver is a Marantz SR5006.
The room is 18' D X 13' W, with ceilings that vault from 10'-13'. My speaker budget is capped right around 1,000. (the Level 2 HTDs come to right under 900.00 for the 5 speakers, shipped). Main uses will be movies (I am an action fan), and PS3 gaming.
Is there anything else I should be considering, or am I on the right track with my selections so far? Looking to order my speakers a week from today, so just wanted some final input before I finalize. Thanks for all the advice thus far!
MBRICHARD is offline
post #2 of 3 Old 12-10-2012, 03:11 PM
rgk
rgk's Avatar
Two pair of PSB B4s and the matching C4 center. Should run you about $700-$750 as the B4s are on special right now for $249 pr. vs $350 a pair.
""The day may come when the courage of men will fail, but it will not be this day!"
rgk is offline
post #3 of 3 Old 12-10-2012, 05:19 PM
zieglj01's Avatar
Quoted: 1555 Post(s)
Liked: 1402
It looks fine - good choices.
__________________________________________
Who AM I
Speakers -- Snell K7 > Q Acoustics 3020 > Boston VS240
Receiver -- Integra 50.2
zieglj01 is online now
Reply Speakers
