Center channel importance - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 12-10-2012, 06:18 PM - Thread Starter
elmorage's Avatar
Liked: 49
In my search for new bookshelf speakers I have read countless threads and review on cambridge s30, infinity p163, psb b4, hsu hb-1, nht abs. zero and others. What I don't understand is why all of the discussions focus on the LR speakers and never really mention the center that gets paired with the set. Is it because they are basically the same speaker or are the sides more important?
I thought I remember being told that the center channel and sub were the most important pieces in a surround system.
elmorage is offline
post #2 of 8 Old 12-10-2012, 06:28 PM
JerryLove's Avatar
Liked: 79
meh.
Honestly: I've disabled the center channel in the majority of the HTs in my and my parent's houses. For me, in those setups, it honestly improved the sound to turn it off.
If you are running one: the center is where the majority of you dialog comes from; hence the importance of how it performs (if you don't run one, the dialog is moved to the L/R speakers).
JerryLove is offline
post #3 of 8 Old 12-10-2012, 06:33 PM
Elihawk's Avatar
Quoted: 1022 Post(s)
Liked: 869
Some of us feel that your front stage (L,C,R) are all equally important...and many of us have run phantom center systems that sound great, so!
If you have a weak center, you won't hear the dialog...but if you have a weak L/R, you will miss so much of the dynamic content of the movie! Equally important....
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is online now
post #4 of 8 Old 12-10-2012, 06:44 PM - Thread Starter
elmorage's Avatar
Liked: 49
That was kind of what I was getting at, in all the threads comparing bookshelf speakers the center is rarely mentioned. So if one of those options had a weak center it would bring the whole system down, or if a center was particularly strong it might swing the decision that way, but it is never really discussed.
elmorage is offline
post #5 of 8 Old 12-10-2012, 06:50 PM
Elihawk's Avatar
Liked: 869
I would say you need to pick the best L/R that has a good center! I would NOT pick a system that had a great center and only good L/R!
post #6 of 8 Old 12-10-2012, 07:04 PM
Kini62's Avatar
Quoted: 1424 Post(s)
Liked: 1319
I have 5 Super Zero 2s. I watched the entire MIB3 in stereo with even realizing it. It might have actually been a little better than when I use the center. And I sit almost in front of the left speaker and yet voices were dead center on the TV.
So I sometime question the need for a center if you have decent L/Rs.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #7 of 8 Old 12-10-2012, 07:26 PM
zieglj01's Avatar
Quoted: 945 Post(s)
Liked: 847
A lot of times something may not be discussed, unless something is not working.
All in all, the best center for bookshelves, is another bookshelf like the L/R ones.
A lot of times people can not do this, due to limited placement. Phantom mode
can work for some people, while a lot of us prefer a center channel. The center
helps to anchor the front stage. > Most of us who have been around, do tend to
recommend nice/working systems.
Here is something to read - from Bluray forum
http://forum.blu-ray.com/showthread.php?p=4278584
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is online now
post #8 of 8 Old 12-12-2012, 12:26 AM
sdg4vfx's Avatar
Quoted: 81 Post(s)
Liked: 140
Originally Posted by zieglj01 View Post
... All in all, the best center for bookshelves, is another bookshelf like the L/R ones ...
+1
sdg4vfx is offline
Reply Speakers
