Onkyo Speakers vs. energy take 5.1 system - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-11-2012, 10:24 AM - Thread Starter
joshgfeller's Avatar
Hello all,
I have a friend offering to sell me an almost new Onkyo HTS-5400 7.1 system for a very good price. My question is on the speaker quality of this system compared to the Energy Take 5.1 setup. I am close to purchasing a ET 5.1 setup and pairing it with a Denon or Onkyo receiver. But, would the 7.1 speaker setup with the Onkyo HTS-5400 be comparable to the sound I'm going to get from the ET 5.1 setup? If so, I may not pass up the deal.
joshgfeller is offline
post #2 of 6 Old 12-11-2012, 01:44 PM
afrogt's Avatar
Quoted: 1067 Post(s)
Liked: 773
I would get the Energy because the Onkyo surrounds only have a single 3.25" cone speaker with no tweeter. They also have a very low sensitivity of 81db.
Even though the Take Classics are small they are a better quality speaker than the Onkyo. Plus I'd get a better receiver like a Denon with Audyssey MultEQ instead of the lower level Audyssey 2EQ on the Onkyo 5400 receiver.
You can also buy the Energy Take Classic 5.0 package for $130 and then add a better subwoofer for about $200.
http://www.newegg.com/Product/Product.aspx?Item=N82E16882269004
Afro GT
afrogt is offline
post #3 of 6 Old 12-11-2012, 01:47 PM - Thread Starter
Thank you for the input. What is the difference between MultEQ and 2EQ? I like the Odyssey receiver in case I ever decided to go 7.1 but maybe that isn't even worth it?
post #4 of 6 Old 12-11-2012, 01:53 PM
afrogt's Avatar
Liked: 773
Audyssey MultEQ actually calibrates and EQ's the subwoofer. 2EQ does not.
http://www.audyssey.com/audio-technology/multeq
Afro GT
afrogt is offline
post #5 of 6 Old 12-11-2012, 01:56 PM - Thread Starter
Thank you. So do you think the Denon with 5.1 and MultiEQ is going to be a better option than an Onkyo with 7.1? I'm thinking about the Denon 1612, Energy 5.0 set, and the Dayton audio 10" subwoofer from PartsExpress.
post #6 of 6 Old 12-11-2012, 02:22 PM
afrogt's Avatar
Liked: 773
Yep, I own 3 Denon receivers. Two with MultEQ and one with MultEQ XT.
I recently purchased the Denon AVR 1613.
Afro GT
afrogt is offline
Reply Speakers
